Headers for a 63 D100
63swept
City: Bend
Post by 63swept »
Does anyone know what headers will work for a 63 D100 with a 273?
Re: Headers for a 63 D100
63swept wrote:Does anyone know what headers will work for a 63 D100 with a 273?
Check out the Hedmann #79010 headers. :study
kman1226
City: Thornton
Post by kman1226 »
Hedman's website says those are for 67-71. What would make them different that wouldn't work on a '63? Has anyone used these for a '63?
kman1226 wrote:Hedman's website says those are for 67-71. What would make them different that wouldn't work on a '63? Has anyone used these for a '63?
Probably the fact that a 63 would have come with a Poly.
I'm going from the information above. It says a 273 Cu.In..
Demulsion has used these with his LA318 in his '68 D200.
The '63 D100 will have the same frame design. I'm assuming
the 273 will have the same exhaust ports as an LA318.
kman1226
City: Thornton
Post by kman1226 »
That is what I was thinking both Soopernaut and Hobcobble.
63swept
City: Bend
Post by 63swept »
Thank you all for your input. Thats exactly what I needed.
61pwcc
City: Hallowell
State: ME
Post by 61pwcc »
Until I found the Dodge burial ground this weekend, I didn't now Dodge pick-ups came with a 273 soo early! I saw a 63' W200 w/273. :2cents
1961 W200 Short Wheelbase Crew Cab
61pwcc wrote:Until I found the Dodge burial ground this weekend, I didn't now Dodge pick-ups came with a 273 soo early! I saw a 63' W200 w/273. :2cents
They didn't ever come with a 273. I suppose anything is possible but these are the engines that Dodge put in Sweptline era trucks: 170,198,225,318,361,383,413,426. The 361 seems to be only medium duty.
Cageman
City: Bismarck
Post by Cageman »
if its an auto, those headers will fit, manual has a different trans mount in the 68 to older that interferes
67 is the first year of la 318's
Cageman wrote:if its an auto, those headers will fit, manual has a different trans mount in the 68 to older that interferes
I believe the #79010 Hedmann headers pretty
much fit all pre-'69 D100/D200 trucks with
auto or manual trannys. If someone knows
anything to the contrary, please chime in.
John :study
