big rear window in a small window cab
nutz
City: phillipburg
Post by nutz »
i have a 67
and just wondering if i could just cut out the cab spot weld the seam and put in a big window
has anyone done this
thanks nutz :thinking
Re: big rear window in a small window cab
To do it correct, you need to remove all the inside panels around the window and replace with big window panels. Its a hella lotta spot welds to cut out and weld back in. Been there, done that.
nutz
City: phillipburg
Post by nutz »
thanks
so sounds like i would need a donor cab
think it will wait ... i want to drive it
Small window is just fine. I have a couple hundred thousand miles with one and all the big window does is make it easy for somebody to aim at the back of your head.
Wildergarten
City: Los Gatos
Post by Wildergarten »
PwrWgnDrvr wrote:
Fri May 13, 2022 8:55 pm
It does make a gun rack look good. Mine is going to have one.
I like the big window for checking my load or dragging logs while negotiating dangerous terrain, checking to see if the dump was complete, etc.
Wildergarten wrote:
Sat May 14, 2022 8:42 am
Big window makes no difference for any of that, especially when all you can see of the dump is the bottom of the box.
Wildergarten
City: Los Gatos
PwrWgnDrvr wrote:
Sat May 14, 2022 9:35 am
You misunderstand, apparently not realizing I've been doing precisely as described for 30 years. The bed headboard is expanded metal, so that I can look through it. I look through that to see if anything is left stuck inside the bed after I have dumped and lowered the bed. If it is stuck, I can raise it again, shake, etc. without leaving the cab. The reason part of the load sometimes hung up was the crane I had mounted on the driver's side back corner. I tried it up front on the passenger's side but heavy loads twisted the bed much more. Didn't like it.
nutz
City: phillipburg
Post by nutz »
i just like the look of it
looks a little sporty ... maybe if i build the 66 and find a donor
but need to finish shop truck first
Wildergarten wrote:
Sat May 14, 2022 2:54 pm
You still don't need a big back window for that situation either.
Wildergarten
City: Los Gatos
PwrWgnDrvr wrote:
Sat May 14, 2022 9:27 pm
It's better. Deal with it.
Wildergarten wrote:
Sun May 15, 2022 8:55 am
Yes, you would know, having never owned or operated a small window truck.
:shame :lol:
I vote keep it small window. keeps the cab cooler on hot days too. less glass to get broken by object being loaded in bed. I like the look of it better also
sixpak340
City: Carlisle
State: PA
Post by sixpak340 »
We have already discussed a fender swap......
I can hook you up with a large rear window cab section & the rear glass too. (the gasket was beyond saving)
nutz
City: phillipburg
Post by nutz »
interesting
i'll e-mail you about it
like i said before really want to drive the shop truck
so don't want to extend this project any longer
but might be cool on the 66
nutz
