Need Exterior Moulding for 1967 D100
- 67D100Pickup
- City: Noble
I'm looking for a complete moulding set like this...
Does anyone know where you can find this?
Jeff
Jeff
Re: Need Exterior Moulding for 1967 D100
Post an ad in the Parts Wanted section.
- 67D100Pickup
- City: Noble
Will do.
Thank you.
Jeff
Thank you.
Jeff
- 67D100Pickup
- City: Noble
I found a complete set for a D200.67D100Pickup wrote: ↑Fri Aug 13, 2021 5:51 amI'm looking for a complete moulding set like this...
Jeff
My truck is a D100.
Does anyone know if they’re compatible? Maybe identical?
@powerwagon, I was told you might know?
Exactly identical all trucks 66-6867D100Pickup wrote: ↑Sun Apr 23, 2023 12:58 pmI found a complete set for a D200.67D100Pickup wrote: ↑Fri Aug 13, 2021 5:51 amI'm looking for a complete moulding set like this...
Jeff
My truck is a D100.
- 67D100Pickup
- City: Noble
That’s what I needed to know.
Thank you!
Jeff
Thank you!
Jeff
Terry, I thought the molding changed in '67 on the door section with the exterior handle change.PwrWgnDrvr wrote: ↑Sun Apr 23, 2023 1:35 pmExactly identical all trucks 66-6867D100Pickup wrote: ↑Sun Apr 23, 2023 12:58 pmI found a complete set for a D200.67D100Pickup wrote: ↑Fri Aug 13, 2021 5:51 amI'm looking for a complete moulding set like this...
Jeff
My truck is a D100.
I think you're right Chris. It seems there was likely no molding in late 65 and 66 due to the bed length/style change and the doors as you noted. So, wide molding probably started in 67.Txas2step wrote: ↑Thu Apr 27, 2023 6:55 amTerry, I thought the molding changed in '67 on the door section with the exterior handle change.PwrWgnDrvr wrote: ↑Sun Apr 23, 2023 1:35 pmExactly identical all trucks 66-6867D100Pickup wrote: ↑Sun Apr 23, 2023 12:58 pm
My truck is a D100.
@powerwagon, I was told you might know?![]()
- City: Binghamton
- State: NY
There are no moldings on my late 65.
I thought it was just another option that wasn’t ordered on my truck.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
wide molding started in 65 and is the same when ordered with all years it was used through 68.
Yes , it is the same size molding late '65-'68 , but the door section changed in '67 to accommodate the change in the outer door handle.
