Mirror placement
- City: Binghamton
- State: NY
Mirror placement
With the pedestal mirrors, when adding a passenger side mirror. Does it mount in the same position as the driver side? ![Thinking :thinking](./images/smilies/icon_think.gif)
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Mirror placement
Yes.BigBlockTrucks wrote: ↑Wed May 05, 2021 10:40 amWith the pedestal mirrors, when adding a passenger side mirror. Does it mount in the same position as the driver side?![]()
- City: Binghamton
- State: NY
Thanks for the info. Now to find that mirror.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- martincom
- City: Five Points
I don't know if it was the same on all years, but on my '71 the inner door hinge reinforcement came drilled from the factory with the three holes. So, all you would have to do is remove the door interior trim panel and utilize those holes as a template to drill the door skin. You're going to have to remove it any way to install the nuts.
Van's had a good price on the chrome plated reproduction pedestals. I utilized SurePlus 310 chrome plated rectangular mirrors I sourced from McMaster-Carr, but they have since ceased to stock them.
- swptln
- City: East Brookfield
- State: MA
They all have the inner frame drilled.martincom wrote: ↑Fri May 07, 2021 3:44 pmI don't know if it was the same on all years, but on my '71 the inner door hinge reinforcement came drilled from the factory with the three holes. So, all you would have to do is remove the door interior trim panel and utilize those holes as a template to drill the door skin. You're going to have to remove it any way to install the nuts.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
