I took the trim off by prying the clips from the side holes the trim and clips came off together this is the wide trim 2-7/8
When putting the side trim back on
do i push the clips in the holes then hook the top of the trim then snap the bottom in ?
if that is wrong id appreciate any help
Installing side trim 67 D200 custom ?
- City: fort lauderdale
Re: Installing side trim 67 D200 custom ?
You install the clips in the molding 1st, in the same location as the holes in truck, insert molding in holes and gently tap in place.
Tex i greatly appreciate the help i definately was going in the wrong direction
