Vent window pivot
- DukePW
- City: Sarnia, ON
Vent window pivot
I finally got the Philips screw head on the vent window pivot to turn after a lot of convincing. Now it's just spinning in place. Is there something acting as a nut on the other side of the vent window frame? Or is that all part of the pivot screw on the other side?
I did the other side a few months ago and can't remember
67 Fargo W100 Utiline
52 International L-110
- Red383
- City: Fort Loramie
- State: OH
Re: Vent window pivot
Are you talking about the screw that holds the vent window frame to the door? The one in the attached picture? If so, there is a spring steel U nut on the door that it screws into.
(Picture stolen from Jim's restoration CD)
- DukePW
- City: Sarnia, ON
No, I'm taking about the pivot on top. I still haven't got back to it, yet I just sprayed a ton of penetrating oil on it and left it.
- Jims68
- City: Edgewater Park
- State: NJ
Sounds like that TOP screw is stripped out. It DOES have threads. See the photo below.
Photo not stolen
Photo not stolen
- pismopowerwagon
- City: Caldwell
- State: ID
So the pin at the top is suppose to stay in framing or glass and screw comes out? Mine screw was spinning pin also, so I took screw out at bottom and came right apart. I would to fix top now while I have apart if so.
Andy
- Jims68
- State: NJ
No, the pin is part of the screw and it comes OUT. The only "PIN" is at the bottom of the vent glass frame where is swivels.pismopowerwagon wrote: ↑Fri Nov 08, 2019 9:45 amSo the pin at the top is suppose to stay in framing or glass and screw comes out? Mine screw was spinning pin also, so I took screw out at bottom and came right apart. I would to fix top now while I have apart if so.
- pismopowerwagon
- City: Caldwell
- State: ID
"Photo not stolen " In your pic at the top of framing I zoomed in and now I see that the part I was calling a pin is part of that phillips screw. It almost looks in pic like there is a nutsert that it threads into and maybe that is the loose part we are both having issues with?
Thanks for explaining
Andy
- Red383
- State: OH
Maybe I should have said borrowed?
- Jims68
- State: NJ
OK, Yeah, I know what you mean. The "SCREW" is threaded at the TOP, and the bottom of the "screw" is a pin and the whole thing should come out when you unscrew it. I can't remember what the frame with the female threads looks like. I'll have to see if I have a frame I can get a picture of without the screw/pin inserted.pismopowerwagon wrote: ↑Fri Nov 08, 2019 1:31 pm"Photo not stolen " In your pic at the top of framing I zoomed in and now I see that the part I was calling a pin is part of that phillips screw. It almost looks in pic like there is a nutsert that it threads into and maybe that is the loose part we are both having issues with?
- Jims68
- State: NJ
Borrowing is always good , it's all good!!
- Jims68
- State: NJ
Found an extra vent frame. Sorry, I thought the screw would've still been there, but it's not. Oh well.....
- pismopowerwagon
- City: Caldwell
- State: ID
I worked mine for a bit and just like you said it threaded apart, I re crimped nut so it should not spin again....tell next time haha
Andy
- DukePW
- City: Sarnia, ON
Ah I understand now thanks
