Finally found some wiper arms .. now to find wipers?
GiS
City: Alberta
Post by GiS »
Hey guys,
Finally found a nice clean set of wiper arms for my 66 D100 .. NOW, does anyone have a part# handy for a set of compatible wipers?
I am getting SO close to getting this on the road I can taste it!
Thanks a ton,
MrMopar
City: Lompoc
Re: Finally found some wiper arms .. now to find wipers?
Post by MrMopar »
I recently went through this on another vehicle and here is what I came up with.
If I recall these trucks use a 13" blade
Correct metal frame style
Trico 43-130
CarQuest 453-130
Functioning substitutes
Trico 44-130
CarQuest 454-130
I think these are Anco (untested)
U13R
19-13
I did check 16" on a different vehicle and just posted what the 13" numbers would be but have not looked for them or tested them.
This should be good start to see if these will work.
Alan
Alan Erland
1967 Plymouth Barracuda
1969 Dodge Polara CHP
1969 Dodge Polara
1970 Dodge Camper Special
www.MrMopar.com
WD
City: Rosemark
Post by WD »
I run 72 F250 arms and wiper heads on my 69 D100. Work fine and a lot easier to find than any pre-72 Dodge stuff.
WD wrote:I run 72 F250 arms and wiper heads on my 69 D100. Work fine and a lot easier to find than any pre-72 Dodge stuff.
Did you use adapters to fit arms or do they have nut device to hold them on. :thinking :thinking :thinking
WD
City: Rosemark
Post by WD »
Pop right onto the splines like they were made for each other. You can use the arms off a real Ford full sized, that means pre-87.
chief915
City: Cecilia
State: KY
Post by chief915 »
My local Napa had regular black wiper blades in stock for my 1970..... They could also order the "classic" style that had the shiny metal frame.
I don't have the part numbers handy, but they looked it up without any trouble.
1970 Dodge Dude
225 / 3 speed manual
sledgehammer
City: puyallup,wa
Post by sledgehammer »
I bought some Anco U-15R for my '68 at a local parts store. Had to cut them down but was the only size they had in stock. They will work.
gyman98
City: Saskatchewan
Post by gyman98 »
I'm running wiper arms and blades off about a 90 Camry on mine
hmaynord
City: fairhope
Post by hmaynord »
this thread is not that old, but any other suggestions for both the arms and shiny blades?
harris
driving it since 12/03/71
