Can you all help me make sense of my door tag? I almost think it is fake. The truck had a manual in it at one time, but the tag leads me to believe it was an auto. All of the mounts and whatnot make me think it really was a manual and someone faked the tag. I really don't care. I'd just like to know. It is a '68. Here's the info:
1181846451 18096609 05200 D100
3600 32 CHRY RA36 000318
2500 3AUTO CHRY A727
17704000 1025 110 128
Making sense of a tag.
- chilort
- City: Cookeville
But what's it all mean.
Idon't know what any of the info actually means. So maybe my ignorance is part of the problem.
It has had a manual in it at some point. There is a hole in the floor pan, a small brake pad, an extra set of holes in the firewall, and 2 trans mounts. Or is that actually normal?
Of course, now it has a '68 440ci and a BB 727. I'd sure like to know how it came from the factory and what all of the numbers mean.
Re: Making sense of a tag.
chilort wrote:Can you all help me make sense of my door tag? I almost think it is fake. The truck had a manual in it at one time, but the tag leads me to believe it was an auto. All of the mounts and whatnot make me think it really was a manual and someone faked the tag. I really don't care. I'd just like to know. It is a '68. Here's the info:
VINchilort wrote:1181846451
S.O. number-sales order numberchilort wrote:18096609
Maximum gross vehicle weightchilort wrote:05200
Vehicle model(2 wheel drive 1/2 ton)chilort wrote:D100
Rear axle capacitychilort wrote:3600
Gear ratio of rear axle(3.23)chilort wrote:32
Manufacturer of rear axlechilort wrote:CHRY
Model of rear axlechilort wrote:RA36
Enginechilort wrote:000318
Front axle capacitychilort wrote:2500
3 speed automatic transmissionchilort wrote:3AUTO
Manufacturer of transmissionchilort wrote:CHRY
Model of transmissionchilort wrote:A727
Net horsepower and RPMs at which it is reached(177 @4000)chilort wrote:17704000
Front spring capacitychilort wrote:1025
This should be rear spring capacity but the number is too small.chilort wrote:110
Wheelbasechilort wrote:128
There are some VIN decoders on the web, including the one on the home page of this site.
- 66patrick
- City: Central
All of these truck have the small brake pedal pad, regardless if it's a standard or automatic. They also have the holes punched out to accomodate either, and the unused holes will have a plastic plug in them.It has had a manual in it at some point. There is a hole in the floor pan, a small brake pad, an extra set of holes in the firewall, and 2 trans mounts. Or is that actually normal?
- chilort
- City: Cookeville
Great Info
Thanks for the great info. I do appreciate it.
I tried to take a picture of the tag but the digital I have doesn't do close up shots so well.
Here's the brakes setup
And a block off plate under the hood next the MC
