I'm also interested in seeing how people attach a screen to the bottom of the cowl vents. I had mine all cleaned out and was just cleaning leaves out again this week. Damn trees!PwrWgnDrvr wrote: ↑Sat Aug 20, 2016 8:57 amU wont keep water out, but I've seen aluminum window screen used under the cover.don6061 wrote:Does anyone have any recommendation on putting a cover on the cowl to keep water and debris out. Thanks.
Donnie
Dash leak into cab
- Red383
- City: Fort Loramie
- State: OH
Re: Dash leak into cab
I used stainless steel screen cut to fit under cowl cover held in place by it and screws. Wasn't hard.Red383 wrote: ↑Mon Apr 12, 2021 8:46 amI'm also interested in seeing how people attach a screen to the bottom of the cowl vents. I had mine all cleaned out and was just cleaning leaves out again this week. Damn trees!PwrWgnDrvr wrote: ↑Sat Aug 20, 2016 8:57 amU wont keep water out, but I've seen aluminum window screen used under the cover.don6061 wrote:Does anyone have any recommendation on putting a cover on the cowl to keep water and debris out. Thanks.
Donnie
- sweatybetty
- City: s.w.
[/quote]Only if the mice don’t have teeth. The oval flap on mine has been chewed through by what could only be mice.[/quote]
Same problem here. They were nesting in the heater box. I put some 1/4" hardware cloth over the holes. Mice cant chew through it and it still drains fine.
- City: Binghamton
- State: NY
[/quote]
I haven’t checked the heater box yet but they have already been in the cowl to make nests. Best thing I have done so far is, I got a cat from the local farm! I put him in the garage one night per week. Same goes for the other garage The mice like to live here anymore.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- City: Thunder Bay
Is this why most trucks have rust holes at the body line of the cabs by the hoods??
1967 D100 Fargo, 318 poly.
4 speed, np435
Carter carb.
4 speed, np435
Carter carb.
- City: Thunder Bay
Is there a simple way to repair this spot? I have looked for some panels without much luck. I will be looking to make my own if all else fails.
4 speed, np435
Carter carb.
4 speed, np435
Carter carb.
I picked up an extra cowl top, I want to try sealing the vents from underneath & smoothing the top for no more vent.
I am good in the heat though, windows down & vent windows open.
I do not need under dash vents.
- martincom
- City: Five Points
I don't what part of the country you live in, but if it is anywhere where the temperatures get low, say less than 40F, you'll have trouble with the windows fogging up. When we breath, our air exhale has a high moisture content. It doesn't take long for all the cab air to have a high moisture content. This, in turn, will be begin to condense on the cold glass, causing it to fog up.
This is why cab heaters bring in fresh air, to change out the high humidity air we exhale and prevent the cab windows from fogging up.
Condensation is not a concern for me?
An open window can let any moist air out.
My hometown averaged 13 feet of rain a year, so I have decades of experience with vehicles in a wet climate.
Double post.
We've exchanged thoughts on vents for closing doors. Is the pressure from the heater sufficient to force air out that type of vent for purposes of keeping relative humidity under control?
Under motion an open window, even partially open will create a vacuum in the cab, pulling air out.
The most important step in controlling in cab humidity is to eliminate all leaks.
Any air out MUST be replaced by air in, from somewhere.
Yes, leaks are way bad. But when its raining outside (humidity around 100%), it accomplishes nothing to bring outside air in. Getting into the cab with rain damp clothes, shoes, maybe a soaked umbrella, you are in a swimming pool of water vapor.
The Subaru is for rainy days.
It has an outside air source -or- hit a button and it only processes in cabin air.
An inside only heater can be McGuivered in, no biggie.
I have enough respect for decodes old vehicles to avoid rain as much as possible.
- martincom
- City: Five Points
On these older vehicles, there is enough air leakage around the door glass and other areas to exhaust the volume the blower motor can produce. For example, if you leave the blower motor off and have the defroster duct open, you'll free air through them, when at speed, with the vehicle. If there wasn't a place for the air to escape, that wouldn't be the case. With a newer vehicle that is sealed up much tighter, I wouldn't be surprised if air displaced by the blower was being exhausted out the cab vents w/check flappers.Wildergarten wrote: ↑Wed Apr 20, 2022 10:59 amWe've exchanged thoughts on vents for closing doors. Is the pressure from the heater sufficient to force air out that type of vent for purposes of keeping relative humidity under control?
True enough. However, when it is raining that hard, the outside air temp is usually much warmer. In turn, the glass is not as cold and condensation, typically, does not occur. Not to say it can't, but not often. It is why every auto I've ever owned that had factory AC, the AC runs when the defroster is activated. Bringing warm, high humidity, air across a cold evaporator coil will result in a large percentage of that humidity condensing on the evaporator coils. This results in the warm air being blown out the defroster vents having low humidity and quickly evaporating any condensation on the glass. I've ran the AC with the heater, in the winter, when I've had a lot of passengers in the vehicle. This quickly eliminated any window fogging and prevented it from re-occurring.PwrWgnDrvr wrote: ↑Wed Apr 20, 2022 1:08 pmAny air out MUST be replaced by air in, from somewhere.
Thx, and it's a fairly wimpy blower by modern standards. I'm still contemplating adding the cab vents. Plenty of time for pondering that when the truck project just sits during weeding season. All I'm expecting to get done this year is the bed painting, underbody boxes, etc, and the driveline. There's logging to do this summer.martincom wrote: ↑Thu Apr 21, 2022 2:29 pmOn these older vehicles, there is enough air leakage around the door glass and other areas to exhaust the volume the blower motor can produce. With a newer vehicle that is sealed up much tighter, I wouldn't be surprised if air displaced by the blower was being exhausted out the cab vents w/check flappers.
