Name that Part!!!
Yellow71
City: 80031
Name that Part!!!
Post by Yellow71 »
First guy to name the application of this grommet is the winner.
HellBelly
Founder
Founder
City: Dallas
Re: Name that Part!!!
Post by HellBelly »
Keith can do a search on that number. I'm sure there are some still on the shelf. If Keith can't find one/two, let me know and I'll get with my NOS vendor i deal with.
calmauzy
City: SoCal
Post by calmauzy »
Parts book shows it as a PVC valve grommet :thinking
I checked and couldnt find any
calmauzy wrote:Parts book shows it as a PVC valve grommet :thinking
Or.... PCV?.... :thinking
Yellow71
City: 80031
Post by Yellow71 »
facechicken wrote:I checked and couldnt find any
No, now see....that is the wrong answer :lol:
Thanks for trying.
Yellow71
City: 80031
Post by Yellow71 »
1 - What year parts book?
2 - This part is a very soft squissy rubber, and would not work well in a high temp app...
and the single black wire...s/b a big clue
BUT!...the search engine I used shows PCV grommet...
However...that is not the answer we are looking for...sorry.
slick
City: Tucson/AZ
Post by slick »
Antenna grommet? Rear cab light grommet? Spotlight grommet?
LC
Post by LC »
LC from PA that part # is not in the 1970 Light,Medium,Heavy Truck parts book and isnot in the 1961 parts book so if it is a truck part it from 62-69 :thinking :thinking I give What,s the Answer :banghead :banghead LC
Yellow71
City: 80031
Post by Yellow71 »
LC wrote:LC from PA that part # is not in the 1970 Light,Medium,Heavy Truck parts book and isnot in the 1961 parts book so if it is a truck part it from 62-69 :thinking :thinking I give What,s the Answer :banghead :banghead LC
You are so right...this part is not in the 1970-71 book...
and yet this part shows up in at least two places on every 1970-71 sweptline...
good job doing your homework :Thumbsup
LC
Post by LC »
LC from PA if it wasn,t 11PM EST I go out and uncover my truck just to find that :censored :censored :censored THING LC
Yellow71
City: 80031
Post by Yellow71 »
slick wrote:Antenna grommet? Rear cab light grommet? Spotlight grommet?
I think you are right on the antenna...but I can't find mine...
I do not know about the rear cab or the spotlight...you may have something there.
However...that is not the application of the grommet pictured...
single small black wire...BIG HINT
Another BIG HINT...I need this grommet, because I just got my rear bumper rechromed, and found that I am missing this grommet, as I am putting the bumper assembly back together,
and installing it on my truck.....
One application for 2426712...Speedometer through firewall...but that is also not the one I have pictured...
Yellow71
City: 80031
Post by Yellow71 »
LC wrote:LC from PA if it wasn,t 11PM EST I go out and uncover my truck just to find that :censored :censored :censored THING LC
L O L...License Plate Lamp wire goes from Rear Bumper...
through grommet installed in bed (under Tail gate)...to harness.
Thanks for participating in this installment of "Name That Part!"
and helping me find more places to look for this grommet.
"This grommet is used in early 60's firewall applications, hood release and radio antenna. Possible choke including truck."
says my friend Rick who just chimed in with that info...
Max Wedge part here for sure...
slick
City: Tucson/AZ
Post by slick »
:banghead . that was my next guess! not really...
robertob
City: Brooklyn
State: NY
Post by robertob »
How is the wiring routed? I have mine dangling under the bumper because I couldn't figure out the routing.
Yellow71
City: 80031
Post by Yellow71 »
robertob wrote:How is the wiring routed? I have mine dangling under the bumper because I couldn't figure out the routing.
This grommet goes in a hole in the extreme rear of the bed. It is on a ground facing surface, under the tail gate.
Your wire goes from the lamp, through the grommet, and is plugged into the harness, which s/b just inside the hole...the plug may be 12 inches to the passenger side...
the harness is then kept by several restraints built into the under side of the bed. As soon as i get mine together, I can get some photos uploaded.
calmauzy
City: SoCal
Post by calmauzy »
Just going off what MyMopar.com part number search came back for part number 2426712, it described it as a “grommet PCV valve”. Thanks for calling me out John on transposing the letters, I think that we all know that I meant PCV. Anyway it was fun to find out just what this part was. Thanks, lets do it again sometime.
http://www.mymopar.com/index.php?pid=99
Yellow71
City: 80031
Post by Yellow71 »
calmauzy wrote:Just going off what MyMopar.com part number search came back for part number 2426712, it described it as a “grommet PCV valve”. Thanks for calling me out John on transposing the letters, I think that we all know that I meant PCV. Anyway it was fun to find out just what this part was. Thanks, lets do it again sometime.
Yes that is what is says...if it was indeed a pcv grommet...my guess is that it may have been a pcv grommet early on, but was obviously replaced with a higher density rubber...
and this grommet was still used in other applications...maybe they were trying to multi task :)
also, this grommet is too big for the valve covers I have...
anyone know if early 60's valve covers have a larger PCV hole??????
Cageman
City: Bismarck
Post by Cageman »
same as an a body, like a duster for the lp light.
