I am putting my late Grandfather's truck back on the road after 18 years sitting dormant. It started life in California and made its way to Missouri in the early 70's where it stayed until the early 2000's when it was brought to North Carolina. The original engine blew around 1995 so Grandpa had a shade tree mechanic replace it. I ended up junking that block as the thrust bearing gave out and the crankshaft ruined the block. It is a 383 engine, 4 speed with a divorced transfer case, and the body has around 70,000 original miles on it. I have installed a new clutch assembly, master cylinder, wheel cylinders all around, and I had to replace all of the brake lines. The front flex hoses were not available from the parts store, so I had them custom made locally which was not too expensive. I had to have the radiator re-cored but I was able to save the top and bottom tanks from the original. Since this is a survivor for the most part and there is quite a bit of cancer in it, I am going to keep it mechanically sound and not worry about the body so much. When asked about fuel mileage, I tell people it consumes about 7 gallons an hour at highway speed. That puts it in perspective as far as cost per hour to drive it ($21 an hour average). The front bumper was fabricated by my Grandpa as he was a retired machinist and he wanted something durable. I have a link to a few photos and I will post more in the coming weeks. Enjoy!
http://s325.photobucket.com/user/DodgeB ... t=3&page=1
1969 W200 Power Wagon
- City: Charlotte
- State: NC
- City: puyallup,wa
Re: 1969 W200 Power Wagon
Looks pretty good to me, have fun with it
- City: Charlotte
- State: NC
Here is a picture of my heater box with a new valve. The original was seized and leaking so I sourced one and made it work.
http://s325.photobucket.com/user/DodgeB ... sort=3&o=0
- hmaynord
- City: fairhope
Ben (CSS-Registry) did something similar:
CSS-Registry wrote: ↑Wed May 26, 2010 4:37 pmi solved this by using a generic valve from BPE - http://www.bouchillonperformance.com/BPEheaterValve.asp
i bought the "BPE3115" and had to re-route the entry point of the control cable.
here's what i did: scroll down to "2009-03 - – Hood, Lights, AC and heater":
http://cssregistry.com/css/64d100Resto/index.html
Ben
harris
driving it since 12/03/71
- City: Charlotte
- State: NC
I am in the process of installing the heater box over the next couple of days. My goal is to route the cable in the stock configuration.
- DocsTruck
- City: Opelika
Cool truck and by the way, if you are still in North Carolina, stay safe, there's a bit of a windy rain maker headed your way.
- City: Charlotte
- State: NC
I am in the Charlotte area. It is going to be a long couple of days as the storm is moving very slow. I am securing items outside so they don't blow around. I have a generator if the power goes out. Should be fine by Monday.
