69 D100 > W100 more pics
- City: spencerville IN
Re: 69 D100 > W100 more pics
I noticed you have a open knuckle front axle. your transfer case x-member goes under the case and you only have two shifters. do you have 5 lug nuts per wheel or 8? and is your transfer case not a NP201. there seems to be a lot of differences between a 68 W100 and a 69 W100
1968 W100 SB 4-speed 318
1968 D200 Custom Camper Special 4-speed 318
2000 Ram 2500 LB 4x4 5.9 auto.
2011 VW Jetta- wifes
2004 Stratus
2008 Avenger R/T
2004 Stratus
2008 Avenger R/T
Beginning in '69, the W100s camemuddyoldman wrote:I noticed you have a open knuckle front axle. your transfer case x-member goes under the case and you only have two shifters. do you have 5 lug nuts per wheel or 8? and is your transfer case not a NP201. there seems to be a lot of differences between a 68 W100 and a 69 W100
equipped with the 5 lug axles. The
t-case changed from the NP201 to
the NP205.
Not only that but this truck was built using an 85 donor truck for parts. So the transfercase is a NP208 and the axles are from the 85.Hobcobble wrote:Beginning in '69, the W100s camemuddyoldman wrote:I noticed you have a open knuckle front axle. your transfer case x-member goes under the case and you only have two shifters. do you have 5 lug nuts per wheel or 8? and is your transfer case not a NP201. there seems to be a lot of differences between a 68 W100 and a 69 W100
the NP205.
- moparbay
- City: Rapid City
- State: SD
soopernaut is correct, this truck is not a good example of an "1969 W100" only the frame and body are from 1969. the entire driveline (minus motor) is from is from the 1985 W150 I used as a donor truck. Motor is a '65 413 out of a new yorker. It is not a good "Reference" truck. Thanks for all the comments....
moparbay
Ole "Blue" 68 D100 Adventurer
65 W100
67 D400
67 W100 (in pieces)
69 D100 converted to 4x4 (SOLD)
65 W100
67 D400
67 W100 (in pieces)
