Wire Fire
- Mavis13
- City: Prescott,AZ
Wire Fire
so i got a new alternater from a junk yard. well looks like he sold me the wrong one because this morning on the way to work i had a nice little wire fire. it looks as if it started from the alternater which turns out to have a internal regulater which mine is a external of course and went to the fire wall and then somewhere under the dash. im not the most happy camper right now. my big question is what do you think i fried the truck wont start i turn the key and nothing. i just dont know where to start. i really want to take the alternater and shove it in the guys butt side ways
ill post some pics tommorow if thatll help
- Seabee
- City: Houston
Ouch man, that's very unfortunate. 1st step would be to start taking the burned wire / harness apart and inspecting how far the damage went from the ALT and repair that. Then inspect at other locations like the starter relay, ignition switch, firewall plugs... to make sure nothing is fried / burned together. (and... be sure to get the proper alt installed).
Does the truck crank but not fire, or not even crank?
- CSS-Registry
- Administrator
- City: Gainesville, Florida
- Mavis13
- City: Prescott,AZ
ok just got done taping the wires nothing burnt together. the fire wall plugs are toast my electical gauge is toast. still need to check the starter wires but last night they felt fine. my battery is also toast.im hoping i got lucky. the only wire that fried far into the cab was the one that goes to the d/c gauge and one came about 2 inches in the cab. well im goin to head out to the junk yard and shove this alternater where it belongs
- Jones
- City: Castle Rock/WA
Mavis,
You'll probably have it up and running, but Id be willing to help you get it running. Here's the catch though, I won't be available until the weekend of the 16th and 17th. So like I said You'll probably have it up and running again by that time.
Keith
Keith
62 D100
63 D100 (Parts)
64 D100
2012 Dodge 1500
63 D100 (Parts)
64 D100
2012 Dodge 1500
- Jeffc
Most likely wire from alt to alt gauge and wire
that is spliced into that alt wire to key.
10g black wire to fire wall from alt,
10g red from fire wall to gauge.
>>need to check 14g pink to switch
plus 10g red to light switch and 10g red to fuses.
these all splice into the feed from the alt.
I have had a alt (the right one) do this
once> it was shorted inside. What should have
been the 2nd field wire was grounded to the
case, like it was for the old points type
regulator. I got lucky and caught it before
the wires got compleaty fried....
- Mavis13
- City: Prescott,AZ
found out it was my fault i grounded the starter wire but the guy i bought it from has another yard he has a dodge van so he is giving me that altenater for half price and giving me the alt wiring i fried.
keith your right already got it running taped all the wires and tossed in a battery started up and ran on the second try just like normal. thanx for the offer though. and thanks all for the pointers and what not
