ignition switch wiring
- greenmachine318
- City: Tucson
- State: AZ
help please? i have to rewire my ignition switch in my 69 d100 any help or pointers would be greatly appreciated thanks.
- greenmachine318
- City: Tucson
- State: AZ
- Jeffc
Switch has marks by each post on the back.
List as follows:
Starting at the top post marked "A" with org. color and wire gauge
A> accessory to wiper switch 12g Light Blue with
splice to fuse box alt reg fuse and 14g red to fuel gauge (buss bar on amp guage)<<12g LB This is the wire
that hooks to the braker on the back of the
wiper motor switch.>>
S> (just below A) 14g orange to fire wall> runs to
the start post on the starter relay
I-2> (to the right side of "I" if not marked)14g pink to ballast resistor- same side as coil
"+" wire
B> above "B" not marked 2 wires
18g blue with white stripe- to brake sentinel switch on brake line spliter box- 18g blue with white stripe
to warning light on dash
B> below "B" - 10g black this wire runs many things-
runs to splice- that then goes to back of amp gauge (10g red), fuse block (10g red), light switch (16g dark blue), Alternator (10g black)
I> 2 wires, 18g black runs to oil pressure light,
16g red runs to fire wall and then to ballast (side
with one wire).
I belive this is all correct.
hope this helps Jeff
List as follows:
"+" wire
with one wire).
- greenmachine318
- City: Tucson
- State: AZ
Jeffc wrote:Switch has marks by each post on the back.
List as follows:
"+" wire
with one wire).
hey jeff thanks a lot that broke it down for me i can now turn key haha
