Based on the color difference, I don't think this is the original wheel for this 68. Fine!
I am worried that I'll push or pull too hard and break something. How to remove the center to starting chasing my non-functional horn?
THANKS
How to remove horn center?
Re: How to remove horn center?
That's a 69-71 wheel, totally different than the earlier wheel.
Gently pry the 3 legs of the cover outward a bit to release the tab inside that fits into a slot on the column.
- City: Binghamton
- State: NY
Also warm it up a little with a heat gun or hair dryer. They can get quite brittle after 50 or so yearsPwrWgnDrvr wrote: ↑Tue Jun 15, 2021 7:52 pmThat's a 69-71 wheel, totally different than the earlier wheel.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
