inoperable speedometer
Help!
Had a friend meshing with wires in the dash, now the speedometer doesn't work. All the dash lights work, fuel gauge works, but no speed.
Is there a fuse for it besides the ones that are under the dash?
- powerwagon54
- City: Washougal
Re: inoperable speedometer
speedo is not electronic.
have a replacement if you need it. Check the cable first.
And what about my horn, it stopped working at the same time.
when I unplug the cable from the speedo and drive, the wire in the cable doesn't spin or move at all.
Is there a good place to get a wiring diagram for these?
What year is your Sweptline?naloleal wrote:And what about my horn, it stopped working at the same time.
naloleal wrote:Help!
Does your friend consider himself an expert on anything vehicular.
Creating a Mesh.... perhaps?dodgeboykim wrote: Does your friend consider himself an expert on anything vehicular.
he considers himself an expert on VERY little apparently, except for teaching me a lesson on who i have work on the truck!
After more reading, and finding a cable hanging by the transmission, looks like somehow the speedo cable come undone from the transmission.
does anyone have a picture of where it screws back in to the transmission, or a good description?
'67 d100 pickup (after doing research, found it wasn't a '66)
naloleal wrote:does anyone have a picture of where it screws back in to the transmission, or a good description?
Just look and it will be apparent on where its attached to rear of trans. Transfer case if a W series.
