Bye,Bye points
Bye,Bye points
Installed the Pertronix "ignitor" pointless kit in the old '61 sixer today . Took about 30 minutes to install. Fired right up.Let's see how see does on the road. I was having a bit of a problem keeping the point gap steady. Found the kit on ebay . Kit was $77.00 delivered.Chris.
rigrunner
City: ararat
State: NC
Re: Bye,Bye points
Post by rigrunner »
post the results im very interested in changing my 70
Re: Bye,Bye points
Me too in my 68, was told petronix is the way to go....let us know :Thumbsup
Re: Bye,Bye points
Fire's right up , idles great, no hesitation on acceleration.So far it looks like a great improvement for 77 bucks! Chris.
gyman98
City: Saskatchewan
Re: Bye,Bye points
Post by gyman98 »
I was fueling up my 67 W200 at the pumps this summer and a guy approached me to tell me about his truck. He claims he installed a chevy HEI distrubutor, anyone heard of that before?
Re: Bye,Bye points
gyman98 wrote:I was fueling up my 67 W200 at the pumps this summer and a guy approached me to tell me about his truck. He claims he installed a chevy HEI distrubutor, anyone heard of that before?
Yes, it happens. :pale :pale :pale
OregonDodgeboy
City: Nampa, Idaho
Re: Bye,Bye points
Post by OregonDodgeboy »
With a little machining, anything is possible. Sad though, I know.
As for the Pertronics, I can attest it's a great product. I put one in my Scout 2's 345 several years ago, and the difference was like night and day. She ran good before, but there was a noticeable improvement right away. No more cranking, fires right off on first bump, when she's warmed up of course. Ran smoother and had more power. I drove the truck every day and never had a problem with it. I picked up some milage too. Not sure exactly what the number was, but if memory serves, I was guessing about 1.5 mpg more at the time. I'd have been just as happy without any milage gains. You will come to love the Pertronics. :Thumbsup
40YearOldFury
City: Parker
Re: Bye,Bye points
Post by 40YearOldFury »
I did a MSD for pretty cheap on my 65 but there are so many other ways to do it too. THe GM HEI is used by everyone it seems. They even make a Mopar distributor that you can mount the GM HEI module on the base of it. Even the Datsun Z guys use it. The way it works is pretty much like the firewall mounted Mopar electronic ignitions. Maybe a little easier to keep a GM HEI in the glovebox as a spare. I just hate putting GM or Ford stuff on my Mopars. You can take a Mopar ignition unit and use it in a Ford or GM too. They all work the same.
I picked up a Mopar electronic ignition unit at the U-Pull here in Denver this weekend for $5 along with the wiring harness. You can buy a lifetime electronic distributor at Advance Auto for about $40. I like the off the shelf parts since my truck is a daily driver and I like to keep it running. Again, I like keeping my Dodge running with Mopar parts.
The Pertronics are pretty decent too. The only thing I worry about is it going bad and then I'm stuck using my thumb because the local parts stores wherever I am don't stock them.
robertob
City: Brooklyn
State: NY
Re: Bye,Bye points
Post by robertob »
The 'HEI conversion' usually just involves the HEI module with a Mopar distributor. The HEI design is superior electronically (uses PWM to limit coil current instead of resistance like Mopar). If you use the right coil you can even ditch the ballast resistor. Though I have seen HEI-style distributors with Mopar shafts from the aftermarket. The pertronix seems like a good setup (electronically very similar to HEI design) but I don't see the advantage over Mopar electronic.
And if you're worried about using "GM" parts on your mopar, don't - I don't think GM (Delco) even makes HEI modules any more!
Rodger
City: COS ( Colo )
Re: Bye,Bye points
Post by Rodger »
Hello All
I too must confess that I have purchased three Pertronic Units.
This was all done one at a time and the first two went into 413's.
The last one was for an 1966 440.
A local MoPar was getting them at a very very low cost.
Rodger & Gabby
COS
Re: Bye,Bye points
www.donzig.com
Its what I run.
Re: Bye,Bye points
robertob wrote:The 'HEI conversion' usually just involves the HEI module with a Mopar distributor. The HEI design is superior electronically (uses PWM to limit coil current instead of resistance like Mopar). If you use the right coil you can even ditch the ballast resistor. Though I have seen HEI-style distributors with Mopar shafts from the aftermarket. The pertronix seems like a good setup (electronically very similar to HEI design) but I don't see the advantage over Mopar electronic.
The advantage in my case( slant six) was all I had to replace were the points and condensor...kept the stock distributor. works for me.
OregonDodgeboy
City: Nampa, Idaho
Re: Bye,Bye points
Txas2step wrote:The advantage in my case( slant six) was all I had to replace were the points and condensor...kept the stock distributor. works for me.
Yeah, the Pertronics works that way too. Essentially it's like replacing the points and condenser. You can retrofit in about 5 minutes if it quits, making the job of keeping a backup in the glove box cheap and compact.
In regards to your original post, How is it running now? When you say that you had unsteady point gap, I have to wonder if the distributor is wearing out. :thinking
CSS-Registry
Administrator
Administrator
City: Gainesville, Florida
Re: Bye,Bye points
Post by CSS-Registry »
I have a Pertronix in my 64's dual point distributor running in my 440. So far it is running great. I think it runs better than the MOPAR unit I was using to chase gremlins with.
Ben
Re: Bye,Bye points
It runs better than ever.The distributor is a rebuilt from O'Reilly , went through 2 to get a decent one from them.
strummin67
City: Santa Clara
Re: Bye,Bye points
Post by strummin67 »
Buick drums were often put to use on Fords. Early Chevy heads found their way onto Model T blocks. All in the name of hot rodding, but I get your point. I've had good results with Pertronix on another car and I will put one on my truck eventually.
