1965 4 headlight; fuse box diagram please
Hello, I was wondering if anyone can help me with the fuse box diagram or pictures? I accidentaly arced some wires on my starter relay under the hood (drivers side fender). I was trying to fasten the relay to the fender when I accidentaly brushed against it with my wrench. It sparked and that was it. Everything works fine except now the temperature gauge and gas gauge are not working. They both worked fine prior to the sparks flying. I believe that I might have blown a fuse. It didn't spell like anything burned. All help is greatly appreciated. Thanks in advance.
Re: 1965 4 headlight; fuse box diagram please
Jim, thank you very much. I checked all the buss fuses in the box. all of them were fine. Does anyone have any idea as to why my gas gauge and temp. gauge may have stopped working after I made the contact with my starter relay?
- City: Austin
I, too, could benefit from a diagram of the fuse box for my '65 crew cab utiline. My truck was bought after sitting in a field for more than a decade so you can imagine how the fuse panel looks! I can't tell what fuse is for what circuit, tons of rust, lots to clean up, poor connections, etc....
that wiring diagram is VERY helpfull, but could use a diagram, or a great pic, of the fuse panel.
Wayne
Austin, TX
Wayne
Austin, TX
