electronic ignition
Sandstone
electronic ignition
Post by Sandstone »
i have a 1963 d100 with a 318 poly. where can i get an electronic ignition setup for it? which ones work the best? part #?
Jeffc
Post by Jeffc »
If your dist is in good shape (no shaft wobble)
Pertronix is a good way to go....
Any LA small block dist will pop right into a
poly....
Mopar preformace kit is a few more bucks, OR...
scavange the wrecking yards and combine
it with a few new parts from the parts store
will give you almost the same for lots less
than a MP kit.
just depends on what you want and how much
you want to spend.....
MSD, Pertronix,ect (LA engine stuff) all sell nice systems
if you want to shell out the change
