Anyone know A/Cs?
- centralwildcat
Anyone know A/Cs?
I was wondering if an AC unit from a 73 d100 with a BB would work for my BB powered 69d200? Anyhelp apperciated, mattc
If you are talking about the compressor and brackets, I would say get all of the 73 brackets and pulleys. You'd be surprised at how many variations there are of pulleys and brackets for big block engines. Also, if the 73 lower water outlet is on the opposite side from your engine some of the brackets won't line up, but you can make them work.
1969 Adventurer W100
- City: COS ( Colo )
Hola Class
The compressor from 1962 to 1978 is the same for any size MoPar car, van or truck. The brackets for any 361 or 383 are the same. The bracket's for the 1972 - 1978 400's are differant. And the bracket's for any 413, 426 wedge or 440 is all the same.
If you now have nuthin and want A/C, the brackets from your engine size can be used from the above information. As others have said, do use the pully's of the same gift.
Rodger & Gabby
Rodger & Gabby
