Wipers
- wideblock
- City: las cruces nm
- State: NM
i would be checking the grounds first. my 66 d100 did funky things till i added a ground wire from the wiper motor to the fire wall under the dash. i would think switch second. the way those things ground sucks, try adding a ground wire and see if it behaves.
grounds first
ducman. What Trey said. My 66 does strange things with the wipers also. The parking problem (in the middle of the windshield ) sounds like a grounding problem at the wiper motor. It amazes me how many of the problems we encounter with our Sweptlines that are caused by poor grounds.
Can't address the switch problem that Steven talked about as mine is on or off. No high/low speeds. BUT the windshield gasket on mine leaks when it rains, causing the ashtray to fill up with water. Could be that water has got into the switch (right under the ash tray) and caused the corrosion Steve talked about.
Blue
Blue
- Seabee
- City: Houston
It's the body control module... oh no, wait... that's what's wrong with my LHS.
RANT! Wiper operation;
Combo switch sends signal to computer body control module. Module outputs to relay bank. Relays power wiper motor. ????????
What does all this get you? Really, really demonic posession type activity from the wipers.
end RANT.
end RANT.
- wideblock
- State: NM
seabee, i have an LHS here in my yard that has great working wipers but a sun crank bearing. slide your engine into my body and you got less of a headache. LOLOL ill be willing to bet you could swap drivelines 3 times as fast as you could fix the wipers.
ouch
Seabee. I hear you man. What a pain. That's why if it has a computer it doesn't stay in my stable. Just wish I could convince the wife of that. Offered to buy her (yea right, her?) a 70 W200 383 4 spd with 4.10s and edelbrock manifold and carb I found for sale. Not interested. She wants a damn scooby doo wagon or something to take the dog for a ride and to bring me home pizza. I bet she gets one pretty soon. Because she spoils me a lot. But who is going to fix it when it breaks? Why is life not fair? I deserve a 70 W200. Really I do. I've been good. Or maybe not.
Blue
Blue
