Dash lights
- plydus340
Dash lights
I put the 383 in my truck. Started having charging problems. I had put a mopar performance electronic ign. in, and a dual plug alt.. Turns out I had a hot wire grounding out on the motor. While I was driving it I noticed the dash lights quit working. The charging problem was the voltage reg.. Charging fine now. Dash lights don't work. Dad said "if the dash lights don't work, the tail lights don't work". Well, the tail lights are working, but no dash lights. Any ideas? Come on gurus, I know you know this one.
1968 D100 727 383
1962 Polara 500 (project)
1973 Plymouth Duster 440 (FAST)
- wideblock
- City: las cruces nm
- State: NM
drop the fuse box and check the connections behind the fuse. if you shorted a wire, id bet you burned one of the spade lugs.
- Jeffc
Yes, check the fuse,
yes, check the bulbs,
yes, check back of fuse box,
the next step would be to check
the light switch reostate coil
and contact......
and contact......
