Hey Guys,
I've been trying to track down this problem for a week now and haven't had any luck. I have a 71 and all lights work except the passenger side rear turn signal and brake light. The housing has a good ground to the bed and I also ran another ground wire from the housing to the frame. I'm not getting any power out of the firewall wiring block that goes to that light like I doing going to the drivers side lights. The interior blinker blinks slow and all bulbs and flashers are new. Any Help?
Thanks
Steve
No Brake Light or Turn Signal on Passenger Rear?
Maybe the switch in the steering column is broken, not making cotact. I am not sure if it would allow the front to work, but I would check that.
Or maybe the contact that the bulb has is bad, or maybe the little contact in the bulb housing is bad, and maybe the wire is bad there too.
You did say the wire has no power , maybe the contact is bad there too, the one in the fuse box wire, where it disconnects. does it have power from the column?
