Turn Signal Lever
- mightydodge
- City: Kansas City/Missouri
Turn Signal Lever
Does anyone know how to remove the turn signal lever from the steering column? I have a 1968 D-100 with three on the tree. My manual states to remove the set screw and then pull out the lever, but I don't see the screw. Grateful for any help someone can provide.
- mightydodge
- MoparN
- City: Carmel
- State: ME
Turn Signal Lever
My 68 D200 auto with the shifter on the dash also just unscrews. It is threaded on the end.
68 Dodge D200
66 Plymouth Satellite
88 Power Ram
04 Hemi Ram
88 Power Ram
04 Hemi Ram
- Jeffc
Yes should be threaded on the end, you should also
see two flat spots near the columm were you can use
a wrench on it if needed.......
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4sp od
Old iron or no iron!
One size does NOT fit all!
62 D100 225 3sp lwb
