Toasted ANOTHER fuel gauge. Ideas?
gwilson09
City: Austin
Post by gwilson09 »
Hello, all...
I toasted yet ANOTHER fuel gauge a little while back. Got the new gauge hooked up (Thanks, Butch), but my temp gauge was not hooked up because it was broken (or so I thought). Gauge worked for all of 5 minutes before it went south and stayed there. Question: Did I screw it up by running the fuel gauge without the temp gauge hooked up? There are multiple threads regarding the operation of the gauges, but it's somewhat confusing to me at this point. As of now all of the gauges work except the fuel gauge and I'm sick of running out of gas. :banghead
All advice appreciated,
Glenn Wilson
40YearOldFury
City: Parker
Re: Toasted ANOTHER fuel gauge. Ideas?
Post by 40YearOldFury »
There is the little voltage regulator on the back of the cluster. That isn't letting too much voltage through is it? Just a shot in the dark.
Sterno
City: Kelowna, BC Canada
Post by Sterno »
The voltage regulator is inside the Fuel Gauge. If the temperature gauge works, the regulator is OK and it's time to check your wiring to the tank and the sending unit.
junior
City: san bernardino
Post by junior »
Install an aftermarket one.One terminal goes to power,another to ground and the other to the sending unit.You also would need an aftermarket sending unit,wont work with original dodge sending unit.I have found them easier to install,they do work well. :2cents
junior
Post by junior »
I ended up just using mechanical temperature and oil pressure gauges,simpler.Less wiring ,less headaches. :2cents
dahobs10
City: Fredericksburg
State: VA
Post by dahobs10 »
All my gages are pretty much shot in my 63', so I'm gonna look at retro fitting some after market gages into the stock cluster.
I already have a 3 pod gage attached under the dash for Oil, Volt, and Temp. Anyone have any input on after market gages? Specificly fuel gage and sender since I am hating not having a fuel gage and relying on the 5 gal jerry can in the bed for my JIC situations.
Are all senders compatible with our "in the cab" vertical style tanks? Anyone done this? Pics?
