Early '65 D100 Utiline rear brake shoes, wheel cylinders
- City: Ontario, Canada
I have an early first gen 1965 D100.
I am looking to buy rear shoes and looking on Rock Auto. I see that there is a difference in the '64 and '65 rear shoes and wheel cylinders.
Since mine is the '65 first gen is it more likely to be the 1964 style of shoes and cylinders, than the later '65-'71 listed?
Thanks for your help
1965 Dodge D100 Utiline
1951 Dodge DG1 (B3B)
1942 Fargo FL1 (WC)
1941 Chrysler C28 Windsor Club Coupe
1938 Dodge D10 Sedan
1942 Fargo FL1 (WC)
Re: Early '65 D100 Utiline rear brake shoes, wheel cylinders
Yes, probably.
And, "first gen" is not a term used in the sweptline era. Early 65 vs late 65 is the common descriptor for that mid yr change. There are multiple yrs that significant changes were made and trying to designate them with "gen" would become extremely convoluted and difficult.
Is there anywhere I could get information that the early 65 were the old style? As shipping to Canada is bad enough, but returns are crazy.PwrWgnDrvr wrote: ↑Wed Aug 31, 2022 11:44 amYes, probably.
1942 Fargo FL1 (WC)
1942 Fargo FL1 (WC)
- my5thmopar
- City: Columbia
Does it have tapered axles? MEANING...A bolt holding the brake drums on. Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
Craig means a "nut", not "bolt", holding them on.my5thmopar wrote: ↑Wed Aug 31, 2022 7:38 pmDoes it have tapered axles? MEANING...A bolt holding the brake drums on. Craig
If you mean a nut holding the drum on like my flathead trucks, where you have to use a hub puller to remove the brake drums off the tapered axle.PwrWgnDrvr wrote: ↑Wed Aug 31, 2022 10:33 pmCraig means a "nut", not "bolt", holding them on.my5thmopar wrote: ↑Wed Aug 31, 2022 7:38 pmDoes it have tapered axles? MEANING...A bolt holding the brake drums on. Craig
This truck the drums just pull off by hand when the wheel is removed.
1942 Fargo FL1 (WC)
1942 Fargo FL1 (WC)
so would think thats the same as my 67 or late 65
i got my wheel cylinders /hardware kit from advanced auto parts ,shoes from napa (well ordered from napa)
I think you would want the parts for a 65. The early 65 trucks had the non tapered axle and the 64 trucks did not.
Thank yousoopernaut wrote: ↑Tue Sep 06, 2022 6:03 amI think you would want the parts for a 65. The early 65 trucks had the non tapered axle and the 64 trucks did not.
1942 Fargo FL1 (WC)
1942 Fargo FL1 (WC)
- my5thmopar
- City: Columbia
Agree!
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
