Frame
PsychopathHenchman
City: Emmett
Frame
Post by PsychopathHenchman »
Is the frame for a 67 the same as a 70 d200 camper specials
Re: Frame
No, not even close!
Re: Frame
PsychopathHenchman wrote:
Wed May 04, 2022 8:58 pm
Re: 100/200 Series Frames
The frames changed in 1969. :study
This is when the hydraulic clutch was replaced
by the mechanical clutch which meant significant
changes in the transmission frame cross member. :salut
Re: Frame
Hobcobble wrote:
Thu May 05, 2022 7:44 am
300 frames too.
nutz
City: phillipburg
Re: Frame
Post by nutz »
are you looking for a 67 frame ,have a 65 100 frame on the parts truck
would love to find it a home
can pm me
Conductorblg
City: Milwaukie
Re: Frame
Post by Conductorblg »
Probably not a significant change to you if you're running an automatic as the bracket for the shift cable at the transmission end on a 67 bolts to a boss on the transmission. The factory did add two crossmembers specific to the automatic, but they are bolt in, and should be easy to move into the rails of the later chassis if they are not already there. Wheelbase and frame length are the same late 65 to 71 (actually 93) relative to the box length.
Re: Frame
nutz wrote:
Fri May 06, 2022 8:17 pm
can pm me
Is it a late '65 long [128"] wheelbase frame?
nutz
City: phillipburg
Re: Frame
Post by nutz »
yes have a late 65 and a 66 both 8ft beds
