Hi guys, I'm in the process of gathering parts to change out the wheel cylinders on the rear (and front) brakes, the one thing I cannot seem to find is a part number or source for the axle gaskets - can anyone help me out here? I assume that RTV or similar could also be used but curious if a gasket exists.
Thank you
D300 Axle gasket part # / source?
- spanxxxdyer
- City: Calgary
Re: D300 Axle gasket part # / source?
Google Dana 70 axle gaskets and you will find multiple hits.
Same as Dana 60 and Dana 80 also.
- City: Binghamton
- State: NY
Permatex is sufficient. But if you are dead set on having a gasket you can buy it by the roll and cut it out yourself
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- spanxxxdyer
- City: Calgary
Thanks guys, I appreciate the help. Never thought to just google Dana 70, but worked like a hot damn.
