Tapered to Flanged swap...Differential needed?
Snowdog
City: Red Deer
Post by Snowdog »
Is it possible to switch the axles from a pre '64 to a post '65 type without switching out the diff?
Thanks!
1961 Dodge D-100
Alberta, Canada
my5thmopar
City: Columbia
Re: Tapered to Flanged swap...Differential needed?
Post by my5thmopar »
Just the axle. Nope. Early has nut on axle. Later is bolted through flange. I’m replacing my 64 now. Craig
Snowdog
City: Red Deer
Post by Snowdog »
Thanks Craig. Is there a step by step guide I can get a hold of?
1961 Dodge D-100
Alberta, Canada
my5thmopar
City: Columbia
Snowdog wrote:
Thu Feb 13, 2020 5:13 pm
Clarify what you're asking. If you replace the entire differential, get a manual. You have to disconnect brake lines, drive shaft, parking brake, leaf springs, install new diff, bleed brakes etc. Take out old put in new assembly. Get a mechanic buddy to help, pretty much basic operation. Now if you want to rebuild one, then there are specialized tools needed and not for the inexperienced. :2cents
