Parking Brake Will Not Release
Posted: Sat Nov 21, 2015 9:05 pm
Need some help. When I disengage my parking brake, the springs don't seem to have enough strength to pull the cable back through and release the brake band from the drum (it's a transfer case mounted parking brake). I've pulled the cable out of the truck and soaked it in evapo-rust to try and make the cable move more freely. I've also added some spacers at the return springs on the brake band to pre-load them. At this point, it's set up so that, when the brake is engaged, the springs are fully compressed and pushing back as much as they can. Still not luck, brake band stays tight on the drum when I release the lever in the cab.
1 - Can anyone tell me how easy the brake cable is supposed to slide? Right now it takes a a fair amount of force for me to pull it back and forth within the coiled sheath that it runs in.
2 - Has anyone had this problem before? Did you go with stronger springs, or replace the cable entirely?
Any help is appreciated.
Buddy
Buddy
