new box power steering
67cspowerwagon
City: maple valley
Re: new box power steering
Post by 67cspowerwagon »
Kurt has done a great job at mocking this up and getting CCP to take a look and I do believe they are thinking about! As for me I going to use the info that Kurt has given us to make one or If I'm going to up input it in the master-cam and just make one part it just as ez to just push start button again I have used CCP part on few car I've built for other people I do like the service and parts,, :clap Just putting out their
kurt
City: Meridian
Post by kurt »
If you didn't see it this link has the solid works and parasolid files to give you a good starting point. We used a CMM to trace my plate so I am not sure if its exact. Do trial fit and modify as needed.
http://redjeep.net/sweptline
1965 D200 Crew 5.9L MPFI/A518
In the meantime, use ball bearings in your kingpins for an incredible difference over the factory washer bearing. :2cents
My 10 minute test drive last night makes me an expert in this area. :joker
67cspowerwagon
City: maple valley
Kurt couldn't get ether file to work but all I need,,, is do you have the X and Y for the hole locations measured out,, is about all I need to put it on a old school mill with digital read outs set a point and go for it Ken
kurt
City: Meridian
Post by kurt »
67cspowerwagon wrote:Kurt couldn't get ether file to work but all I need,,, is do you have the X and Y for the hole locations measured out,, is about all I need to put it on a old school mill with digital read outs set a point and go for it Ken
I PM'd you something. You know it would be a lot easier if you just buy the parts and tranfser punch the plate they give you with the box. I am leary of the drawing of my plate. We used a brand new measurment system on it but I never verified anything.
kurt
City: Meridian
Post by kurt »
[quote="67cspowerwagon"] As for me I going to use the info that Kurt has given us to make one or If I'm going to up input it in the master-cam ......
I am not a mechanical engineer but have exposure to 3D modeling SW and machining. I did a quick google search and I belive my solid works file can be importred to master cam.
RH62
Post by RH62 »
I'm sorry if I missed it. What kind of pump and bracketry did you guys use? I have a 440 in my truck. I see the crank has extra pullies. Will a 60s/70s style ps pump work?
67cspowerwagon
City: maple valley
It should been thinking about the pump pressure myself and I starting down the road on doing this it should be fine Should have an up date this week on the plate see how it going fit
67cspowerwagon
City: maple valley
OK GUYS who'S GOING TO WANT A KIT TO DO THIS POWER STEERING SWAP GET BACK TO ME need some Ideas on how many people want to do this
Last edited by 67cspowerwagon on Mon May 12, 2014 11:25 am, edited 1 time in total.
CSS-Registry
Administrator
Administrator
City: Gainesville, Florida
Post by CSS-Registry »
67cspowerwagon wrote:OK GUYS who'S GOING TO WANT A KIT TO DO THIS POWER STEERING SWAP GET BACK TO ME SHOULD HAVE A PRICE LATER THIS WEEK
what are you supplying?
Custom Sports Special
& High Performance Package
R E G I S T R Y
RH62
Post by RH62 »
I'm def interested. I would want to know the overall or even approximate cost so I can plan for it.
mousecat
City: Modesto
Post by mousecat »
67cspowerwagon wrote:OK GUYS who'S GOING TO WANT A KIT TO DO THIS POWER STEERING SWAP GET BACK TO ME need some Ideas on how many people want to do this
I would also be interested, if you feel so inclined!
RobertGilliam
City: Clinton
Post by RobertGilliam »
Me toooooooooooooo!
Papac3
City: Kennard
State: NE
Post by Papac3 »
Me three! :dance
carterkid63crew
City: Westminster
State: MA
Post by carterkid63crew »
Me 4!! lol. I called classic performance and ordered my box a few days ago. I havnt had a whole lot of time and buying one would save me from having to fabricate my own. 67csPOWERWAGON What exactly would you be includeing in this "kit"? From the sounds of your earlier posts you have the ability to duplicate the steering box mounting plate that Kurt so generously made available to us. Is this one item what you are refering to?
RH62
Post by RH62 »
When you called them did you ask about their "kit" that they are working on?
67cspowerwagon
City: maple valley
So yea where able to CNC plate But the pit men arm is the last deal too work out with my friend that builds hot and race car chassis He;s going be able to sell a kit with the box plate and pitmen arm it we can get a lot of order it going to be cheaper up front where still working on some details post pic and more info as we make head way
RH62
Post by RH62 »
Is there a solution for connecting the new box to steering column?
CPPFRANK
City: LONG BEACH
Post by CPPFRANK »
Hello Sweptliners,
I have been in contact with Kirk and now I will share with you.
We are in the R&D stages of the box at this moment which means we have a few prototype boxes that we are installing to determine which is the better fit.
The few of you that have already created a bracket and installed it have determined that the the column is having to be moved. Our concern is that once we start producing this box we will get the phone calls about this issue and will have customers upset.
Currently we have gotten it as close as 3/8" further from the frame and 3/8" lower than the stock box. We are trying to solve this by clocking the box slightly or altering the mount to raise it up slightly.
For those of you who have already installed it and asked, the box is ment to run at pressures between 900-1200PSI. Most pumps on the market today run at these pressures.
Hirschy41
City: Kingsburg
Post by Hirschy41 »
I cant wait until this kit is done. This, the disc brake conversion AND potentially finding a donor cab to get my floorboards replaced all in a matter of days....sweet!
Please notify us all when this kit is ready to go! Thanks.
Eric
66 D200 Crew Cab
69 Mach I Mustang
