Been trying to get my 67 D200 running and am now down to rebuilding the carb. Looks to be a Bendex Stromberg WW. Any ideas where or even if I can get a rebuild kit for it? If not, what is a good replacement for said carb. The gaskets are shot in mine and the leather seal that used to be the accelerator pump is in shambles. Looking for some help.
Thanks
Aaron aka olred
Bendex carb on 66 318?
- wideblock
- City: las cruces nm
- State: NM
i rebuilt the stromberg on my 66 318 with a kit from napa. never did get the accelrator pump to not leak. 3 kits, no luck, guess the bore was just too shot. but i swapped it with a carter from a bit newer, 69 i think. easy rebuild, and made the truck run better then the strom. it was smoother accelerating, and seemed to have more pull at the top rpm. i recommend the swap. unless you just want to say to heck with it, go to the speed shop, get you the wieand 4bbl for the poly and a nice edelbrock 600cfm carb
- Jeffc
used a Hygrade (made by Standard)kit on my 65 273LA Carter 2bbl
346C. should be the same number or close.
