I for the first time in my life now have a vaccuam guge and would like to experiment with setting the carb and timing with it, now do ya set the carb first, or do you set the timeing first with the gauge???
![Study :study](./images/smilies/icon_study.gif)
Robin,MountainMoparRobin wrote: I actually have it running better off the ear and tune than other methods, by the way its also set up for emissions right now with the 101 jets, will be changing them soon steping up larger, had carb shop do some work on the carb last year and got it set for emissions, will take it back so they can use the machine and we are going after at least 2% of raw power instead of the current 1%, I'm also running 3lbs of fuel pressure so under full throttle it starves alittle but thats simple adjustment just turn up the fuel regulater
Robin,MountainMoparRobin wrote:Hey Jeff I knew you have done this, this was on the 440 I built, and keep in mind I'm at 6000 feet above sealevel, the instructions give the adjustment for the altitude, but any way idling, around 900 rpms, this is with the Mopar Purple cam 484/484, keep in mind idling is also a constant lumpy lope until 1200 rpm, the gage at the carb was 10 and it made only 1 hg change no matter how far out I turned the air fuel mixture screws, then with just less than half inch of advance it went to 17 hg and of coarse the more advance I went the more vacuam, but the advance was way too much for it will ping under heavy excelleration, thats with 9:5:1 compression and everything is set for Rpm ranges 1500-6500 rpm, and yes it will do the 6500 rpms I also run Hemi valve springs, and of coarse I have the MSD 6AL ignition system, the distributor is curved and 4 degree advance on the crank
I'm thinking you might do better with a slightly different curve due to the elevation. I am at about 350' above sea level so not much elevation here. When I went through CO my rig was not running very well at all. I stopped in Leadville and pulled into a lot near the school. Then I saw the sign on the back of the bleachers that said "Proud to live in Leadville, CO, elevation 10,200'.MountainMoparRobin wrote: Russ you got it I've been driving it and deciding if it could be better and trying different aproaches, and funny I'm considering doing a different curve, there is a curve kit in it but don't think I like it. I'm going to do some more messing with it before winter for early next spring I have something I'm going to add for more fast horsepower.
