Hey friends, I was hoping a transmission guru may stop by as bud help me ID this 4 speed transmission. I was thinking it may be a NP420. It only has three bolts per side on the top case, but the drain and fill plugs kind of looked like a NP435… any thoughts from the Sweptline crew?
Cheers, Matt
Transmission identification- 61 power wagon
- City: Whitehorse
- Attachments
- D4707473-0BF5-4062-8FD2-40A174CEF68A.jpeg (36 KiB) Viewed 574 times
- 07475975-C8EF-4090-BFCF-1E65B0904B30.jpeg (33.25 KiB) Viewed 574 times
- B35B0440-0D1F-44FF-924F-6E07FE043894.jpeg (33.9 KiB) Viewed 574 times
- 020124C8-1DBC-4F65-BCA1-6FF0A74EAF9E.jpeg (31.48 KiB) Viewed 574 times
Re: Transmission identification- 61 power wagon
Not a 420. They have a cast iron top. 435 has an aluminum top.
- City: Whitehorse
Yes I agree. I believe this was once painted a silver colour.. but I’ll actually check tonight if it is actually aluminum or not..
Does transmission have a metal tag bolted to trans using PTO cover bolts.
- City: Whitehorse
Looks like I should have just looked at the data plate on the drivers side door! It appears to be a Borg Warner T98 transmission.
I’m still looking into it more, but it appears to be a unusual transmission, as it was typically used by Jeep.
The research continues..
yep even the Canadian military M37 dodges used the Acme T98. i wonder if all the Canadian Doges used Acme??
When you say all are you just referring to military. I have a D 300 VIN Tag showing the T 98 and a couple showing the 435. One is a 67 (435). The other 2 would have to be VIN dated.
