Valve Springs 318 Polyhead
My cylinder heads are at the machine shop, but the valve springs I was sold Melling Part# VS150 have a spring pressure of 180. In the OSM spring pressure should be between 137-150 for both intake and exhaust springs. The free length for the Melling springs is correct at 2" Will they work? I do not want to have valve train trouble later on. If not, is there a good Mopar part # for the correct springs?
Re: Valve Springs 318 Polyhead
You should call Gary Pavlovich( 619 572-3008 CA) . He is the Guru for the Poly. Very nice guy and a world of Poly knowledge. ![Thumbs UP :Thumbsup](./images/smilies/icon_thumright.gif)
- swptln
- City: East Brookfield
- State: MA
Are you replacing the cam? If so, I'd be more concerned with cam spec and recommendation from cam manufacturer.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
