Gas Pedal and Linkage Change
bigfick
City: Johnstown
Post by bigfick »
I’m in the process of putting my 62 Ute back together. I put at 440 with 727 in her, and am in the process of putting throttle cable gas pedal back in. The stock design won’t work and I was hoping you guys could help.
Will a 70-71 pedal and cable bolt right up? Any modifications? Any other ideas? I was wanting to get away from the floor mounted pedal to the firewall mounted design.
I had an extra pedal from my 70 duster and it seems to be a little short unless I fabricated a mount to hold it couple inches from the firewall.
Thanks for looking and helping me out here.
Wildergarten
City: Los Gatos
Re: Gas Pedal and Linkage Change
Post by Wildergarten »
bigfick wrote:
Sun Apr 12, 2020 10:19 am
I put a cable linkage into my old '69 using a Campagnolo bicycle brake cable. Don't remember what I did about the pedal, but it was made for one (had that funny keyhole notch in the end of the rod to hold the lug on the end of the cable). It might have come from my old '64 Dart. For the termination at the carb, I cross drilled a 5/16 bolt and squeezed the cable between washers. Lasted 30 years. I MAY still have it. IF I do and you want it, I'll send it for the price of shipping in a flat rate box. Probably about $15. Probably needs a new core cable.
Might be quicker and easier to make one.
The '69-'71 Sweptline pedal isn't a direct bolt in. I think you could make it work though. :Thumbsup
bigfick
City: Johnstown
Post by bigfick »
I appreciate all the feedback, I think I will attempt making the 69-71 pedal work. I would imagine the pedal length is a bit longer than the Duster pedal I have, they look very similar. Will post a pic if I can get it. Thanks again, Jason
my5thmopar
City: Columbia
Post by my5thmopar »
Not sure why yours won't work. The rod setup works perfectly in my 64/440. I did however use a Lokar kD. Like already suggested, use the later cable style :2cents
bigfick
City: Johnstown
Post by bigfick »
I might have to revisit the original pedal if I can find it. I could have sworn it was resting on my valve cover last time I had it sitting there. Thanks for the input, I like the idea of having a cable if I could go that route.
Wildergarten
City: Los Gatos
bigfick wrote:
Mon Apr 13, 2020 8:58 pm
It gives a much better feel than the rod linkage, but the trick is that the kickdown has to tie into the carb linkage. Being a fan of manual transmissions, I haven't done that one.
problem with cable compared to rods is reliabily. cables fail, rods don't. on custom builds I will attempt to go rods if I have the room. lasts forever.
Kaegi wrote:
Sat Apr 25, 2020 10:28 am
Hmm, Cables fail. Wonder when the cable conversion on my 66 is going to fail. Been in truck since 1983. Linkage was crap due to flexing and surging when off road. Never liked linkage throttle. :thinking :thinking Also converted my 70 D 500 to cable due to carb and engine change.
Wildergarten
City: Los Gatos
Forever? I've seen cheapo factory automotive cables fail. I'd bet if any you've seen fail weren't Campagnolo stainless bicycle brake cables in nylon-lined sheaths. I've had one work for 30 years with no problem and that was a crappy installation too. Had another car with one and put 187,000 miles on it without failure. Rod linkages get sloppy, the clips rust and bind too if not lubed. So really this boils down to personal preferences as long as good system components are installed and maintained.
marklein
City: Red Deer
Post by marklein »
The issue with rod style linkage is it is part of the cab, the engine is mounted on rubber mounts and move differently than the cab. A good cable always feels better than linkage to me. I am using a 360 magnum and the amount of travel required for the throttle body is a lot. There's about 6 inches of throw above the pivot pin on the magnum pedal. This will be interesting. I have seen 2 different ways that the 69-up pedals are mounted, I have one that has 2 bolts in the bracket for the pedal, another that has an extra bracket bolted to the main bracket. To use the later cable, you'll need to cut a hole in your firewall, then make it square for the cable to snap into.
marklein wrote:
Sat Apr 25, 2020 9:12 pm
I used a Dodge Dart A body pedal assembly in my 66, Cable attached to pedal assembly instead of a square hole in firewall. It no longer has the pedal pivoted from floor. Pedal is hinged on arm instead. In my 70 D500 I used a 70's Chrysler C Body pedal assembly allowing me to use the original hinged Swept style pedal.
bigfick
City: Johnstown
Post by bigfick »
dodgeboykim wrote:
Sat Apr 25, 2020 10:40 pm
If you have any pictures it would be very helpful...the pedal project got a little sidetracked for me. I've been working on my fenders, finally got them painted and ready to mount to the cab. I felt the A body pedal was too short, but would love to see how you made it work. Thanks, Jason
I used the short pedal. Eliminated the Original floor mounted pedal in my 66. I can send a few pics. Message me your e mail address. :salut :salut
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Post the picture here for all of us to see.
Please.
Aaron
Red383 wrote:
Wed May 20, 2020 2:11 pm
Please.
Aaron
66 W100
70 D 500. Pedal is flipped back for picture. I put a hinge into it due to old hard rubber.
70 D 500 gas pedal.jpg (17.01 KiB) Viewed 1455 times
Conrad
City: Austin
Post by Conrad »
I can't help much as I don't know what pedal assembly was used by the prior-prior owner, but it does look like the a-body style, but reversed. I'm using the metal linkage. It's janky as you can see here as it rests on top of the wiring. I had to move the bolt holes over as the pedal was too close to the brake pedal for my wide feet.
I have experience with the cables and can vouch that when you have it set up properly it is very nice. Go with the name brand vs. trying to save a few bucks. As long as the cable is routed freely and lubricated, they are reliable.
Assuming I do upgrade my engine, I will go with a cable at that point. For now my setup is livable.
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Thanks Kim.
What is the benefit of having a floor mounted pedal versus the firewall mounted pedal? Or vis versa. Is there a benefit to one or the other or is it preference?
Aaron
Wildergarten
City: Los Gatos
Red383 wrote:
Fri May 22, 2020 6:13 am
In vehicles with carpating, I prefer the firewall mount, as it doesn't need a slot or hole in the carpet. With rubber mats, it might be different, but I don't know. I'm hoping someday somebody makes one for this truck. One might be able to bolt through the mat, in which case it's a push in principle. I just prefer the cable linkage, so it may be the firewall mount for me.
Thanks Kim.
Aaron
When I installed the pedal assembly in the 66 W100 back in 1983 it did not have the floor mounted pedal. I had the cable parts laying around and chose to use it. Never missed the floor mounted pedal. Carpet was installed a year or so later.
In my 70 D500 it still had original pedal so the Chrysler C Body gas pedal assembly worked well with original pedal.
