What Flywheel
What Flywheel
I am Having a problem finding the right flywheel that works with this NP4530 transmission i am told its the same as a NP445 its just named differently and a 318 poly engine.
The dilemma i am having is that i used the smaller size 10 1/2 inch clutch flywheel and its too small as it sits too far way from the starter. I then tried the 11 inch clutch flywheel and it will not slide into the bell housing of the transmission. I am at a loss right now to know where else to look i have searched online but to no avail.
Am i missing something or a trick here to get these two to marry together.
Re: What Flywheel
Just dawned on me the truck is a 1975 D100 and i have been searching for the flywheel for that year which is where i am probably going wrong. Can anyone help and let me know what year these trannys would be used between so i can find a flywheel that was used in those years instead. Or guide me to the right flywheel thanks
Re: What Flywheel
What bell are u using? U need the flywheel and starter that go with the bell. Everything else has to match those 3.
Re: What Flywheel
I didn’t pick the bell housing its what the transmission was cast with its all one solid piece.
Re: What Flywheel
To confirm..... You're trying to install the transmission in a 1975 D100?
- City: Fort Collins
Re: What Flywheel
PwrWgnDrvr is correct.PwrWgnDrvr wrote: ↑Thu Sep 12, 2019 10:07 pmThat is NOT a NP445!!!
I have 3 of them and they are not cast that way. The bell is separate.
I have an NP4530 in my garage and it's not cast with bell, the bell is a separate part.
Ken
Re: What Flywheel
Sorry for the confusion guys I’m a novice obviously. The issue I’m having is when i try to mate the tranny and the engine together the flywheel is with too big and will not allow the tranny to slide up against the engine or when i use the other flywheel its too small for the starter to catch the teeth of the flywheel.
I am trying to find out what flywheel is used with the NP4530 tranny and a 318 poly engine.
Please help guys I’m lost
Re: What Flywheel
I think if you post pics some on here will know the asnwers
Re: What Flywheel
Probably best to post up pics of the truck, the bell, the Poly and the flywheels.DapperDaz wrote: ↑Fri Sep 13, 2019 10:23 amSorry for the confusion guys I’m a novice obviously. The issue I’m having is when i try to mate the tranny and the engine together the flywheel is with too big and will not allow the tranny to slide up against the engine or when i use the other flywheel its too small for the starter to catch the teeth of the flywheel.
You might not get too far otherwise....
Re: What Flywheel
Please see images attached hopefully it makes a lil more sense now guys. Fingers crossed
- Attachments
- A147F39D-0858-46B8-8497-98215B7DA3B6.jpeg (44.73 KiB) Viewed 849 times
- 97B829BA-871C-490F-9E61-FB0130C10FF0.jpeg (38.12 KiB) Viewed 849 times
- A53D81E7-1791-48F1-B200-554377B2D21D.jpeg (43.1 KiB) Viewed 849 times
- FEF1882E-57E5-40CE-BEEA-B7864073B3E4.jpeg (51.9 KiB) Viewed 849 times
Re: What Flywheel
Pics are difficult for me to see, but I do see that the engine is NOT a poly 318!
What is that engine really and what did it come out of?
What did the 4530 come out of?
You may be trying to mate a dog to a cat - won't work......
Re: What Flywheel
To further Terry's points.....PwrWgnDrvr wrote: ↑Fri Sep 13, 2019 6:11 pmPics are difficult for me to see, but I do see that the engine is NOT a poly 318!
Make certain that you do have a LA318. The LA360
looks the same, but uses a balanced flywheel.
Also, is there a part number on that bell housing?
That would help to be able to look it up to see the
specific applications.
Does that NP4530 have a 23 spline input shaft or
is it 10 spline?
to confirm from your pic.
Re: What Flywheel
Here is a photo of the engine casting number 4104230-318-14 hopefully this will shed some light on the matter
The input shaft has 23 splines
Re: What Flywheel
Ok, its a 318. That doesn't mean *#%^ for what you're asking. As I said to start with - the flywheel and starter HAVE TO MATCH THE BELL!!! Regardless if the bell is integral or separate from the tranny. So if you really want to know "What Flywheel", get it from whatever that tranny was attached to! You haven't answered the question above - WTF did u get that tranny?
Re: What Flywheel
That tranny came with the truck when i bought and the engine when in the bed of the truck. They mate together perfectly but i am struggling to figure out the flywheel that should be used on it its killing me. One is two small and the other too big some one please help me
![Salut :salut](./images/smilies/icon_salut.gif)
Re: What Flywheel
Google these and start reading:
https://www.google.com/search?rlz=1C1KM ... 4uSwQJV5kE
https://ramchargercentral.com/vehicle-h ... cess-4spd/
http://www.ifsja.org/forums/vb/archive/ ... 54801.html
Dave at the site below is extremely knowledgeable, contact him and u may get the answer:
http://www.jobrated.com/tranmission-id.html
Re: What Flywheel
In re-reading your second post on the 12th, I'm trying to figure out what theDapperDaz wrote: ↑Thu Sep 12, 2019 12:13 pmJust dawned on me the truck is a 1975 D100 and i have been searching for the flywheel for that year which is where i am probably going wrong. Can anyone help and let me know what year these trannys would be used between so i can find a flywheel that was used in those years instead. Or guide me to the right flywheel thanks
truck is, exactly, that you're working on.
'75 D100 back together or is there another [Sweptline
here?
Re: What Flywheel
Probably why they were in the bed!DapperDaz wrote: ↑Mon Sep 16, 2019 1:23 pmThat tranny came with the truck when i bought and the engine when in the bed of the truck. They mate together perfectly but i am struggling to figure out the flywheel that should be used on it its killing me. One is two small and the other too big some one please help me![]()
- swptln
- City: East Brookfield
- State: MA
Re: What Flywheel
Sounds like you have NP445...........if so? your going to need a bell housing and flywheel for a 69-up small block.
I can tell you this, that bell housing is nothing I've ever seen for a 69-71 Dodge truck small block. I think you need to do some research on that bell housing.
I've never seen one with that square inspection hole on the top...........Just as point of interest, that bell housing unbolts from the tranny, it's not one piece as you mentioned.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
