Dakota 5 spd to poly 318
builder
City: strathmore
Post by builder »
Dakota 5 spd to poly 318 is this do-able, i heard comments on drilled crankshaft for pilot bearing the truck has a np435 in it now but would like to bring the revs down on the hwy, I have swapped LA318 to poly 727's but this is different ?, thoughts anyone , experience doing this swap?
Re: Dakota 5 spd to poly 318
You are probably running a 3:91 rear gear....change to a 3:23 if you are just trying to lower the rpm. Much easier. :2cents :Thumbsup
builder
City: strathmore
Post by builder »
actually runnin 355, but going to change over to posi will keep that in mind
slick
City: Tucson/AZ
Post by slick »
I would think its possible. The bellhousings are the same bolt pattern, so I don't see why not? Keep us updated.
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
PowerMan
City: Auburn
Post by PowerMan »
I did an LA340 to a NV4500 swap which is similar. The Nv4500 uses a non integrated bellhousing unlike the NV3500 (Dakota 5 speed). Both of these transmissions were an option being the Magnum series 318 (5.2) and 360 (5.9) in the mid 90's to early 2000's. I held the NV4500 bellhousing up against the back 1962 Poly 318 I have and it had an issue with the two lower bolts at the bottom of the block not lining up. The 4 or 5 bolts along the top of the bellhousing line up just right along with the two dowel pins. While on the LA series engines, all of the bolt holes and dowel pins lined up.
I also used a Magnum 318 flywheel behind my 340 as they are a neutral balance while the Magnum 360 flywheels are not.
Also I was able to press the input shaft roller bearing in the back of my 340 crank without a problem. I know this may vary on other years and engine sizes so that may need to be addressed.
The poly and LA both bolt to the exact same hydro bell in 67/68, so how can they be different, and if so, how was that addressed in those yrs?
PowerMan
City: Auburn
Post by PowerMan »
I went back and checked the bolt pattern on the Magnum Nv4500 bellhousing vs the bolt pattern on the 1962 Poly 318. All bolt holes and dowels line up except the lower driver side bolt hole.
Here is an example, my Dad's 64 W200 originally had a 318 Poly and later switched to a 1972 340 engine. After checking his truck it was apparent that he had drilled and tapped a hole in the Poly bellhousing to accomodate for the new hole location for the LA 340 engine. This new hole location is almost exactly in between the existing hole and the dowel pin in the bellhousing.
I also took a look at the Poly 318 bellhousing I had used behind my 1969 LA340 engine before the NV4500 swap, and it is apparent by the grease mark on the bellhousing that the LA340 had a different location for this lower driver bolt.
So in conclusion, if someone wanted to solve this problem while using an Nv4500 bellhousing or nv3500 transmission behind the Poly 318, they could easily drill the extra hole in the lower driver ear on the Poly 318 block.
On the other hand if someone was using the Poly 318 bellhousing behind an LA engine (assuming all LA engines have the same bolt pattern as the two LA340 engines I have used), a hole can be drilled and tapped to accomodate the new hole location required with for the LA engine.
My assumption is that the bellhousing hole location was changed in 66/67 when Dodge switched from the A to LA 318 series.
I have only seen the different poly bolt pattern on 61 and earlier blocks. any chance your polys are 61 or older?
