NP435 questions
NP435 questions
Hi Guys, I need some input. While pulling the transmission out of my early '65 W200, i noticed it is a 10 spline input shaft. When I ordered a clutch for it, everything I can find says it should be a 23 spline. I wonder if it was changed at some point in the past. I know its a close ratio transmission(NP435A with 4.56 1st vs NP435L with 6.68 1st) which i thought was odd for a 4WD truck. Can anyone else confirm what their truck has in it? The tag on stamped into the PTO cover says 2508034 D-3, 8 18 64 435. Thanks for the help!
1965 W200
1996 FZJ80 Land Cruiser
2019 Ram Power Wagon
Re: NP435 questions
Its a stock trans. 23 spline started in 69. 10 spline prior yrs. "Everything u can find" don't know squat!
Re: NP435 questions
And www.hrclutch.com WILL have what you need. Give them a phone call. Several members here have dealt with them, including me although I wasn't shopping for NP435 parts.
- City: Evansville
- State: WY
Re: NP435 questions
If you're wanting to buy local try Casper Auto, Inland Truck, Drive Train Industries or Napa. Not sure about the service at Napa and DTI now days but it is very rare to get the wrong parts from Casper Auto and Inland Truck. Or, sounds like hrclutch may be the way to go, I'll be checking out their website when I get a chance. Thanks for mentioning the site Bucky!
1961 W500, 1965 W200, 1967 D100, 1971 W200 and a few parts trucks.
Re: NP435 questions
Thanks for the replies guys. I was hoping that most of the parts listings were wrong for my year and it is a 10 spline. Can anyone confirm that these trucks use a close ratio, tall first gear instead of the granny low? wypowerwagon440, It's good to see another local power wagon guy!
1965 W200
Re: NP435 questions
Most of the 4 spd swepts came with a wide ratio trans, but some were ordered with the close ratio. They're both out there, but the wide ratio is much more common. What eng do u have? Close ratio with anything but a big block is not so good for off road.
Re: NP435 questions
I have the 318 Poly. It's currently being bored and stroked to a 392.
1965 W200
- RussRoth
- City: Vancouver, WA
Re: NP435 questions
Actually for the most part it downright sucks even with a BB. Mine was originally a close ratio which Dad ordered because as a street racer at the time I thought close ratio was the way to go. Not so for offroading though.PwrWgnDrvr wrote:Most of the 4 spd swepts came with a wide ratio trans, but some were ordered with the close ratio. They're both out there, but the wide ratio is much more common. What eng do u have? Close ratio with anything but a big block is not so good for off road.
![Turn Pale :pale](./images/smilies/icon_pale.gif)
![Shame :shame](./images/smilies/icon_shame.gif)
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
- City: Evansville
- State: WY
Re: NP435 questions
Not sure where you are on the engine build but Gary at Pentastar Performance is very good. He has a shop out at the airport and is on Facebook, I can get you a number if you need it. I work second shift at Westech in Mills and one of my Power Wagons is usually in the lot across the street. Not always driving a Sweptline but feel free to wheel in and check any of them out. My weekends are pretty jammed up right now but we'll have to hook up sometime.wyota884 wrote:I have the 318 Poly. It's currently being bored and stroked to a 392.
Re: NP435 questions
Ive got a 392 real hemi for sale and a 4v manifold to go with it.wyota884 wrote:I have the 318 Poly. It's currently being bored and stroked to a 392.
- Roxyflash
- City: East Moline
- State: IL
Re: NP435 questions
The close ratio was used in camper specials i have one also that was ordered on a cab only d200 with slant six
Re: NP435 questions
Gary has my engine right now. Should be cool when it's done. I'll have to swing by and check your trucks out sometime.wypowerwagon440 wrote:Not sure where you are on the engine build but Gary at Pentastar Performance is very good. He has a shop out at the airport and is on Facebook, I can get you a number if you need it. I work second shift at Westech in Mills and one of my Power Wagons is usually in the lot across the street. Not always driving a Sweptline but feel free to wheel in and check any of them out. My weekends are pretty jammed up right now but we'll have to hook up sometime.wyota884 wrote:I have the 318 Poly. It's currently being bored and stroked to a 392.
1965 W200
