big block swap
bigks3
City: little rock
State: IA
big block swap
Post by bigks3 »
I just pulled a 383 and automatic out of a 1974 power wagon. the oil pan is a rear sump. there was plenty of room. But everything I read says i need a front sump pan to put this engine and tranny in my 1970 w200 crew cab. will this setup work as it is?
WAWII
City: Rolla
State: MO
Re: big block swap
Post by WAWII »
Trucks are normally rear sump, while cars were normally front sump. Where were you getting the info on needing a front sump for a truck?
Will
1946 Dodge Power Wagon http://powerwagon.wawii.com/46.html
1949 Dodge Power Wagon http://powerwagon.wawii.com/49.html
1953 Dodge M37 http://m37.wawii.com/
1964 Dodge W500 Fire Truck http://powerwagon.wawii.com/W500.htm
2006 Dodge 3500 Mega Cab http://wawii.com/My3500Megacab/index.htm
kurt
City: Meridian
Re: big block swap
Post by kurt »
I would swear my 1965 crew had a front sump but someone could have dropped a car engine into it. My engine code, vin number and registration are all different years. I put a 360 magnum in it with a rear sump and was worried but the sump is fully behind the axle.
1965 D200 Crew 5.9L MPFI/A518
Re: big block swap
WAWII wrote:Trucks are normally rear sump, while cars were normally front sump. Where were you getting the info on needing a front sump for a truck?
Sweptlines used a front sump pan but many have found they have enough room to use a rear sump pan.
digdoug
Re: big block swap
Post by digdoug »
:goodpost
91w350 CTD
93w250 CTD
Re: big block swap
Every V8 [318 / 383] Sweptline I've owned had a front sump. :2cents
swptln
City: East Brookfield
State: MA
Re: big block swap
Post by swptln »
Correct, 61-71 trucks are all front sump. 72-93 trucks are rear sump. Pass. are mid sump.
Mark D.
61-71 Dodge Truck Association
1968 W200 Sweptline
1969 D100 Utiline
1993 D250 Club Cab
