Grinding Gears
- Cody100
- City: Inwood
Grinding Gears
So I tried to go for a ride this afternoon and when I went to leave I couldn't get my truck in gear. I tried 1st, 2nd and 3rd and each time it was grinding pretty bad, I could force it in but that made my heart hurt just a bit. I also noticed that even when I had the clutch right to the floor when I was putting pressure on the stick the truck started to roll... So my question is what could be the issue and where do I start to look?
Cody
1966 D-100 Custom
1966 D-100 Custom
Re: Grinding Gears
'66 so it has hydraulic clutch. Bleed the clutch.
Re: Grinding Gears
Definitely a hydraulic issue. Make ure the master and shave are not leaking also.
- Cody100
- City: Inwood
Re: Grinding Gears
I've been browsing the forums looking for help on bleeding/servicing the clutch but all the posts I've come across are a little bit over my head, technically and mechancally speaking. Does anyone have a good link to clutch service for dummies? ![Laughing :lol:](./images/smilies/icon_lol.gif)
Cody
1966 D-100 Custom
1966 D-100 Custom
Re: Grinding Gears
Its similar to bleeding brakes, have a friend help you.
Re: Grinding Gears
Doug told me a method once that worked well. It involves filling the reservoir and then you put the bottle under the truck with a hose from the open bleeder into the bottle of fluid. This draws fluid while you pump. I'll try to find the post. It worked well for me at the time.
Re: Grinding Gears
Here is the thread:
viewtopic.php?f=19&t=19295&p=179628&hil ... ch#p179628
And make sure you bench bleed the master before installing. It really is crucial. Bench bleeding involves working it on top of the bench and getting all bubbles out.
- mopardwh
- City: Longview
Re: Grinding Gears
Good luck Cody. Any more questions ask away, this forum is really excellent for getting help.
- Cody100
- City: Inwood
Re: Grinding Gears
I think I figured out the problem, I crawled under my truck the other day to get a soccer ball and i saw that the slave was wet. I had my son pump the clutch a few times and oil started leaking out rather quickly, the clutch is also very easy to press now. Is the slave serviceable with a seal or rebuild kit or do I need to look for a new one?
Cody
1966 D-100 Custom
1966 D-100 Custom
Re: Grinding Gears
I believe you can service them. I will say that having it sleeved with stainless is a great option. I send my stuff to John Geidl in the midwest. For now if you are on a budget, you can get them fairly cheap at NAPA and the like.
- Cody100
- City: Inwood
Re: Grinding Gears
Probably worth while to check the whole system? If the master is working fine should I just leave it or take the oportunity to do some maintence? Normally I go with the old "if it ain't broke don't fix it" but my mom always said "an ounce of prevention is worth a pound of cure".
Cody
1966 D-100 Custom
1966 D-100 Custom
Re: Grinding Gears
Check the clutch master for signs of leakage in the engine compartmentCody100 wrote:Probably worth while to check the whole system? If the master is working fine should I just leave it or take the oportunity to do some maintence? Normally I go with the old "if it ain't broke don't fix it" but my mom always said "an ounce of prevention is worth a pound of cure".
and also inside the cab on the firewall where its mounted. I would say if
you can't see any signs of trouble, replace the slave cylinder, bleed the
system out and go from there.
- RussRoth
- City: Vancouver, WA
Re: Grinding Gears
IMHO you would be far better to replace both master and slave. I have been around mine from day 1 and if you forget to change fluid even remotely regular (like me) you get maybe 5 or 6 years out of both of them. Trust me when I say nearly 100% of the time if one is bad the other is not far behind. Hence I am currently in the process of changing mine out today. I got the master in before it hit 100* and way past time to quit.
Maybe finish tomorrow if I get to it early AM. The good part is in '95 I bought lifetime replacement from Schucks which O'reilley now owns. I have all the paperwork since then too and they stood behind the warranty so I got my 112 bucks back.
Thumbs up to them although the counter guy said that was part of the deal. BTW, he was quite impressed I had all receipts and they were in such good shape. I just told him I had acquired a 4 drawer file cabinet at some point and I have a file from when I rehabbed the rig with a stack of receipts over 2" thick.
![Turn Pale :pale](./images/smilies/icon_pale.gif)
![Dance :dance](./images/smilies/icon_dance.gif)
![Clap :clap](./images/smilies/icon_clap.gif)
![bang :banghead](./images/smilies/icon_bang.gif)
RR
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
Vancouver, WA
'67 W200/450 CID
AA OD/SM465/205
PTO winch
4.10 powerlock
8R19.5 tires
- Cody100
- City: Inwood
Re: Grinding Gears
Alrighty gentlemen we just had a long weekend and what better time to be working on your swepty? I purchased a new master and slave from Piston Ring for about $120.00 including brake fluid and some shop rags. Then I spent a glorious day tinkering in the garage
The first problem I came across was my hydraulic lines were seized to the nuts, they came loose from the slave and master but the whole line wanted to twist with it. I ended up having to cut it off at either end so that I could get the nut out without ruining the entire line. Lukily I had a flare tool collecting dust on the shelf that finally earned its keep. The second problem was the master cylinder did not come with a hose for bench bleeding, after some searching I was able to make use of the junk in my garage and bleed the master with it bolted to the fire wall. After that it was a simple matter to bleed the slave and oh boy did it feel good to have a stiff pedal again!
Cody
1966 D-100 Custom
1966 D-100 Custom
Re: Grinding Gears
Nice!
