318 Poly Head Bolts that need sealant?
63Dino
City: Ft Worth
Post by 63Dino »
Does anyone know which head bolts will require RTV sealant when re-installing the heads? I think it is the lower bolts only but i'm not sure. Also, Is it good practice to lube them first, then put the RTV on top of it or do the opposite?
Also, do other fasteners require sealant that may be in the water passages - exhaust manifold studs? intake manifold?
I want to get this thing back together and don't want to screw up. :pale Thanks for any help
40YearOldFury
City: Parker
Re: 318 Poly Head Bolts that need sealant?
Post by 40YearOldFury »
I think a couple of the bolts by the exhaust go through water passages. The ones up higher are not and do not use sealant to my knowledge. Here is a good thread on another board that should have all your answers. That is the Poly 318 Yahoo group. These guys live and breath the Poly motors! http://autos.dir.groups.yahoo.com/group ... ssage/7539
