chattering clutch
chattering clutch
bad news. I replaced my clutch disc and resurfaced the fly wheel becuase my rear oil seal was leaking and old disc was oil soaked. After putting the rebuilt disc in STILL get bad clutch chatter, grab, when I take off. I did not replace the pressure plate or throwout bearing. these only had about 5000 miles on them, I only replaced the disc thinking a new disc would stop the chatter.
Do I need to drop the tranny and start over with new everything???? People have told me that they have had same prob. with rebuilt discs. Think its the rebuilt disc? Should I have put in a new pressure plate also??? Anything else I can look for as the culprut for clutch chatter. Its pretty bad. Whole front end shakes when I take off.
Fish
Fish
Re: chattering clutch
You might want to remove the inspection cover and look up into the68fish wrote:bad news. I replaced my clutch disc and resurfaced the fly wheel becuase my rear oil seal was leaking and old disc was oil soaked. After putting the rebuilt disc in STILL get bad clutch chatter, grab, when I take off. I did not replace the pressure plate or throwout bearing. these only had about 5000 miles on them, I only replaced the disc thinking a new disc would stop the chatter.
Fish
pressure plate to see if any of the springs shifted or failed in any
way.
plate and throw out bearing that only had 5000 miles on them.... unless
your kid was out doing hole-shots with it...
What year?
Are we talking gear grinding?
1965 NP 435 tranny, 1977 360, No gear grinding. Shifts OK driving, just major chatter when taking off. Im just going to bight the bullet and order a new disc (not rebuilt) new pressure plate new throwout bearing, and put it all in one more time.
Fish
Fish
But what year truck?
My hydraulic system needed a new slave cylinder and that fixed my grinding...... 61-68? or 69-71?
65?
65?
I believe Ron is working on his early '65 D100.
Is your 360 of the vintage that would require a balanced
flywheel? I'm just curious as to which flywheel you're running.
What are you calling chatter? Are you talking noise or vibration? Do you get feedback (pulsation) from the clutch pedal too?68fish wrote:bad news. I replaced my clutch disc and resurfaced the fly wheel becuase my rear oil seal was leaking and old disc was oil soaked. After putting the rebuilt disc in STILL get bad clutch chatter, grab, when I take off. I did not replace the pressure plate or throwout bearing. these only had about 5000 miles on them, I only replaced the disc thinking a new disc would stop the chatter.
Fish
Ryno
- thedodgeman69
- City: reno
- State: NV
I just put a new clutch pack in my 69 w200. It also has a 360 in it and it now shudders when taking off. It feels like when you try and take off fast in reverse and the truck starts hopping. That's the best example I can compare it to.
What flywheel are you using in your truck?thedodgeman69 wrote:I just put a new clutch pack in my 69 w200. It also has a 360 in it and it now shudders when taking off. It feels like when you try and take off fast in reverse and the truck starts hopping. That's the best example I can compare it to.
- thedodgeman69
- City: reno
- State: NV
What type of clutch linings did you select?thedodgeman69 wrote:I just put a new clutch pack in my 69 w200. It also has a 360 in it and it now shudders when taking off. It feels like when you try and take off fast in reverse and the truck starts hopping. That's the best example I can compare it to.
Can you creap the vehicle around (continually slipping the clutch without fully engaging) and the shudder goes on non stop?
- thedodgeman69
- City: reno
- State: NV
I'm not sure what brand of clutch it is. My friend bought it several years a go for his road runner and decided he wanted a different clutch. It probly came from napa or another local parts store. I tryed slipping the clutch and it doesn't chatter. Only when I take off from a stop.
So, it's not the friction material. When you take off at a higher rpm, does it get better or worse?thedodgeman69 wrote:I'm not sure what brand of clutch it is. My friend bought it several years a go for his road runner and decided he wanted a different clutch. It probly came from napa or another local parts store. I tryed slipping the clutch and it doesn't chatter. Only when I take off from a stop.
- thedodgeman69
- City: reno
- State: NV
Hi rpm makes it shudder. If I lug it, it takes off ok.
Did you resurface the flywheel, before you installed the new clutch?thedodgeman69 wrote:Hi rpm makes it shudder. If I lug it, it takes off ok.
- City: portville new york
Had this happen when I owned my 70 Superbee....found trouble to be a bad pilot bushing
Fish - How are you doing with this?
Steve
Steve
