Fuel injection question
Seff
City: Bellingham
Post by Seff »
What are your guys thoguht on installing a fuel injection system on a slant 6? im planning on installing a turbo on my 63 dart, but i dont really want to deal with modifying the carburetor. What do you guys think?
F6866
City: Morgantown, WV
Re: Fuel injection question
Post by F6866 »
There is a fuel injection section on slantsix.org.
Seff
City: Bellingham
Post by Seff »
Thanks :salut
40YearOldFury
City: Parker
Post by 40YearOldFury »
Throttle body injection and a Megasquirt!!!
DavidWymore
City: El Centro (of nowhere)
Post by DavidWymore »
I'd venture to guess the *cough* GM V6 TBI could be pretty easy and cheap. MPFI is the best though. I wonder about putting the injectors in the manifold instead of in the head...
If you decide to do throttle body and there isn't an adapter out there, let me know, if you twist my arm hard enough and I get the urge, I might make an adapter.
Seff
City: Bellingham
Post by Seff »
40YearOldFury wrote:Throttle body injection and a Megasquirt!!!
yea, that could work, but will it work with a turbo?
DavidWymore wrote:I'd venture to guess the *cough* GM V6 TBI could be pretty easy and cheap. MPFI is the best though. I wonder about putting the injectors in the manifold instead of in the head...
ill have to look into this, im currently drawing out a few ideas that are in my head. i know one of the ideas ive got is to cut and shorten the stock intake on a slant and modify it to have better air flow from the turbo, and have the fuel injections right before the end of the intake. but if the throttle body injection works, it would look more stock with an air filter... :thinking
40YearOldFury
City: Parker
With a Megasquirt you can do a Turbo and the TBI with an adapter can bolt on just like a carb. If you are a purist and want Mopar equipment you can look for a late 80's 360/5.9 TBI Mopar throttle body and make that work too. If you want to modify your manifold and put one injector per cylinder you can do that too and run a later model V8 mopar throttle body as well. Megasquirt gives you the ability to tune just about anything. There are even fancy things like wasted spark, sequential fired injectors, and using the Megasquirt to controll your timing and advance. You will also want to put in a O2 sensor to make tuning a little easier. They are pretty neat. I'm still working on mine and learning more about them but there is a huge online support community. Just do a Google search and you'll see. I'm just running a Holley Pro-Jection throttle body on my 318 Poly and keeping it simple to start. You can order the kits fully built or as a kit and solder it all together yourself if you have the skills. http://www.diyautotune.com/catalog/inde ... 19d9e3bf9b
http://www.msefi.com/posting.php?mode=q ... 7&p=243727
DavidWymore
I have a '91 W350 360 engine out back with the throttle body on it, but nothing else, scrapped the truck.
40YearOldFury
City: Parker
DavidWymore wrote:I have a '91 W350 360 engine out back with the throttle body on it, but nothing else, scrapped the truck.
Now someone needs to make an adapter for the Mopar Throttle body to fit onto a carb designed manifold! You can always use MDF or something like a 3/4 inch thick heat risistant kitchen cutting board though. Hmmmm?
DavidWymore
Aluminum...
40YearOldFury
City: Parker
Aluminum...
That would be ideal...but...Yeah, I don't have those skills or tools! lol Hey...If you are offering though! Need to adapt a 360 1988 vintage throttle body to a 1957 318 Poly 4bbl intake. You know the kind that came with the WCFB carbs.
DavidWymore
I don't have those parts, so I would need a dimensioned drawing...
