unexplainable whine...
j2007
City: 58318
Post by j2007 »
So one the beast warms up, it is running fine, Drives around real good, until it is decelerating after a hard acceleration.(as when you are moving 5-10 mph and goose it to spin the tires, then let off) The sould is almost like a "whine" and appears to be coming from the motor or most likely the transmission. I am running a 727 automatic. Is there any adjustment that could be out of spec? Don't know much about at transmissions so I am in the dark here....
"American Iron"
EGroscup
City: Escondido
Re: unexplainable whine...
Post by EGroscup »
Is my ex riding with you?
63d100sixer
Post by 63d100sixer »
EGroscup wrote:Is my ex riding with you?
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
I was wondering the same thing about my ex:
"why are you doing that!??"
"do you have to drive so fast?!?!?!?!!?"
"what the HELL were you thinking!!!!!"
as far as the truck making the noise, have you checked the fluid level in the tranny??
1968 D200 318 727
1972 D100 360 4 speed
1973 d100 318 727
1973 W100 440 727
j2007
City: 58318
Post by j2007 »
:goodpost
ya, fluid is good.
"American Iron"
High pitch, or low pitch, and only on decceleration? and if I read right, deccelleration after heavy acceleration? :study
j2007
City: 58318
Post by j2007 »
MountainMoparRobin wrote:High pitch, or low pitch, and only on decceleration? and if I read right, deccelleration after heavy acceleration? :study
Its not a sqeek, but not quite a growl. you did read correct decelleration after heavy acceleration.
thanks
jared
"American Iron"
How many belts do you have? 1 or 2, as in fan belts, power steering, A/C?. :thinking
Oldguy
City: Reno
Post by Oldguy »
Carrier bearings in the rear end? I had a noise, sort of a whine on deceleration in my 66. Changed out the pumpkin and it went away. Just a thought. Good luck. Mike
j2007
City: 58318
Post by j2007 »
I will have to check that out next time I am at the shop. Hopefully there will not be snow on the ground :pale . The carrier bearings are new, maybe the transfer case has something to do with it?
"American Iron"
I would also look into the rear end. Sounds like a more common issue.
66Fargocrewcab
City: High River
Post by 66Fargocrewcab »
If you drive your truck at say 40mph and manually downshift the transmission from 3rd into 2nd, does it make the same whine? Could be the planetary gears in your tranny, and that's pretty common.
j2007
City: 58318
Post by j2007 »
66Fargocrewcab wrote:If you drive your truck at say 40mph and manually downshift the transmission from 3rd into 2nd, does it make the same whine? Could be the planetary gears in your tranny, and that's pretty common.
Have not had him out on the highway yet, but I have heard that as a problem from another website.
"American Iron"
