Can anyone help me out with adjusting my clutch pedal? NP435 on a 318. The Clutch grabs 2" from the floor and there is a ton of free play at the top.
Thanks!
Clutch Adjustment
Re: Clutch Adjustment
Hydraulic system?
Either set-up, the linkage is adjusted too short. But the remedy is obviously approached differently based on what you have. On mechanical the adjustment is on the linkage between the Z bar and clutch fork. Not sure on the hydraulic version.
- slick
- City: Tucson/AZ
- State: AZ
On the hydraulic set up the adjustment should be on the slave cylinder. Adjust the rod on it if I remember right..
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
