Old gas
Old gas
Have a couple fuel tanks with yrs old gas in them. Have added octane booster in the past to assuage some of the loss and burn it thru the motor. There are numerous choices at the parts store. Anybody have suggestions on what the differences are, how to compare, how much to use or what else works to deal with old gas?
Draining the tanks is not an option.
Re: Old gas
Just so you know someone has read this... no, I don't have any suggestions other than maybe Marvel Mystery Oil?? :thinking I remember when we had cars behind our body shop that sat there for years, we would drain out the gas and use it. Of course... that gas was probably the older stuff that had lead and such in it. I too would save that gas and maybe use it in lawn mowers and such.
Re: Old gas
I was taught in tech school (30 yrs ago) that stale gas has higher octane than it did when it was fresh. This was pre-ethanol of course.
I would recommend SeaFoam.
Re: Old gas
All the old gas Ive ever run, starting in the 70's, has knocked like hell! (stinks like it too!)
I'll get some of that Sea Foam. Beach is pretty close to here....
Re: Old gas
lightning4x4
City: cave junction
Re: Old gas
Post by lightning4x4 »
Ive always used old gas for cleaning extra greasy parts ,it works so much better than the degreasers they sell today just my :2cents
Re: Old gas
Jumping Jehosaphat ! For the 7 years I've been on this site, this is the first time I've seen Terry ask for advice. This is a special day. :lol: :joker
DavidPope
City: Eston, Sask, Canada
Re: Old gas
Post by DavidPope »
Syphon it out and use it for fire starter! Modern stale gas will gum up the carburetor.
Re: Old gas
I have used this product many times with great results.
http://www.starbrite.com/startron
Andy
SoleSurvivor
City: Torrance
Re: Old gas
Post by SoleSurvivor »
pismopowerwagon wrote:I have used this product many times with great results.
Starbrite rules. But...its not a miracle worker. If your gas has been sitting for two years you should be OK. 5 years or more detach the fuel line at the fuel pump and let gravity just drain that tank. Replace the fuel filter and remove the gas cap. I drained mine(mine had been sitting for 20 years) into an old gas can and dropped it off at the local oil, old gas, e-waste drop off. Old gas is just going ruin everything down the line.
Fresh fuel will do wonders.
1962 Fargo Torrance, CA
SteveH
City: Auburn
Re: Old gas
Post by SteveH »
I'd drain it into a container, check for sediment, and transfer it to a gas can,
and then add a gallon or two of it to a daily use vehicle every week or so.
That would get rid of the old stuff by diluting it with twenty + gallons of new stuff.
Slow,...but effective.
