Kickdown linkage
- POWWAG
- City: Maple Valley
Re: Kickdown linkage
If you had the tranny cooler lines plugged off the lack of flow was probably starving something to do with the upshift. I believe the kickdown has something to do with the same. There is also an adjustment for the kickdown on the side of the tranny that I believe preloads a valve. I am not a tranny tech so further investigation is in order.
The ball joint on mine appears to thread in and out on the rod. We need to find a factory carb to see the geometry of the throttle arm. Then I could add to mine and you can confirm the hole in your add on is the correct distance from the throttle shaft.
Don
Don
- marklein
- City: Red Deer
The linkage from the carb to the trans is what the trans uses to raise the line pressure in conjunction with the amount of throttle you are inputting. The amount of throw at the carb must be approximately the same as it is at the trans or the correlation between throttle opening and line boost will not be correct. At full throttle, the arm at the trans must be all the way toward the back of the trans. Leaving a small amount of play between the sliding linkage at the carb and the stud on the carb will let the carb reach full throttle. Either system will work ok, although the bellcrank style does not deflect like the one piece one can.
- POWWAG
All of that agrees with my understanding, so why the slot on the fixed kickdown? The kickdown in my rat truck has the fixed linkage off the throttle cable pin and the previous owner put a spring on it rendering the slot inoperative. Full throttle does deflect the rod to the tranny slightly.marklein wrote:The linkage from the carb to the trans is what the trans uses to raise the line pressure in conjunction with the amount of throttle you are inputting. The amount of throw at the carb must be approximately the same as it is at the trans or the correlation between throttle opening and line boost will not be correct. At full throttle, the arm at the trans must be all the way toward the back of the trans. Leaving a small amount of play between the sliding linkage at the carb and the stud on the carb will let the carb reach full throttle. Either system will work ok, although the bellcrank style does not deflect like the one piece one can.
great info. and perfect timing. put a afb on my 318 and it doesn't have a kickdown hole for my rod style. need to find a way to fab one i take it?
- POWWAG
So I can steal my own thread, right? On the rat truck the slotted piece is about 4" long, it and the rod to the tranny meet at a common point on a pivot. On a 77 Power Wagon I use to mud race (440/727) with simular kickdown linkage and I had replaced the slotted piece with an adjustable rod thus allowing me to move upshift points (RPMs). The rat is a 360/727 and I want to 1/8 mile drag this thing and it is shifting way late. I have to back out of the throttle to get it to upshift when I'm doing test hits. Here is a pic of the 46 Dodge rat.
Don
Don
sorry i didn't mean to steal your thread.
great looking rat by the way
- marklein
- City: Red Deer
There is supposed to be a return spring on the linkage. It usually runs from the top of the bellcrank to the carb, #4 in the pic, thus returning the linkage as the throttle is reduced. I am not sure why they used a slotted piece at the carb, makes it easier to get on and off , and without the slot I think it would make the adjustment harder, as the slotted piece is normally threaded. Never drive a torqueflite without the linkage hooked up and adjusted properly, damage will result.
- POWWAG
No theft, no worry! Do you have the carb that came off of your truck?Spdcrazy wrote:sorry i didn't mean to steal your thread.
Don
yes sir.POWWAG wrote:No theft, no worry! Do you have the carb that came off of your truck?Spdcrazy wrote:sorry i didn't mean to steal your thread.
Don
- POWWAG
Spdcrazy wrote:yes sir.POWWAG wrote:No theft, no worry! Do you have the carb that came off of your truck?Spdcrazy wrote:sorry i didn't mean to steal your thread.
Don
2 barrel? Sell it? Willing to ship?
PM me
Don
