transmision help...
- City: chappell
- State: NE
transmision help...
Trying to figure out what type of clutch i need. my pickup (1968 dodge d100) has a 318 v8, its got the original slant six 3 speed tranny, it has a 318 fly wheel and a ten inch clutch plate with a 11 pressure plate, the input shaft has 10 splines... need help im lost....
Re: transmision help...
Sir
lean on The Counter at NAPA and let them listen ( and take notes ).
Rodger & Gabby
Rodger & Gabby
Try these guys....wilmothcody wrote:Trying to figure out what type of clutch i need. my pickup (1968 dodge d100) has a 318 v8, its got the original slant six 3 speed tranny, it has a 318 fly wheel and a ten inch clutch plate with a 11 pressure plate, the input shaft has 10 splines... need help im lost....
http://www.hrclutch.com
If you go to NAPA or other local auto parts stores, make sure they
order the correct parts for a hydraulic clutch LA318 truck. As '69
was the first year of the mechanical clutch [and 23 spline disc], they
might order in the wrong items.
You have the correct clutch disk for BOTH the 318 and truck /6 in 68.wilmothcody wrote:Trying to figure out what type of clutch i need. my pickup (1968 dodge d100) has a 318 v8, its got the original slant six 3 speed tranny, it has a 318 fly wheel and a ten inch clutch plate with a 11 pressure plate, the input shaft has 10 splines... need help im lost....
X2 on HR Clutches!
None of the local auto supply houses here in Houston have been able to produce a '61-68 11" 10 spline clutch disc and pressure plate for our trucks...keeps coming up 23 spline. I have spent hours in them all to no avail. Even tried Rockauto.. HR has the proper parts you need. Not cheap but you get quality stuff. Local shop can rebuild my old stuff, but I'm going with HR.
So is there a definitive answer here? I have a 67 w300 with the same setup? I pushed the truck out and its waiting
HELP
HELP
ecfuerst wrote:So is there a definitive answer here? I have a 67 w300 with the same setup? I pushed the truck out and its waiting
HELP
I'm not sure if the w300 clutch is different than the d100's..... maybe someone can chime in on this. If it is the same, then it would be the 10 spline 11" inch set up and I would contact HRclutches....they can fix you right up .
www.hrclutch.comecfuerst wrote:So is there a definitive answer here? I have a 67 w300 with the same setup? I pushed the truck out and its waiting
HELP
Call them to confirm.
They should have what you need.
- Roxyflash
- City: East Moline
- State: IL
not sure if the 300 using a 11 or 12 inch clutch i have a 318 poly out of a d500 it has a12 inch clutch 1966
I called a place called custom clutch and he went to the pare catalogs. He found that D400 and up came with that set up. However, he could not order it. he could piece meal it together. I also found another local part store with paper that did the same think about $160 plus core. It will take a week. I'll look into the USPS boxes(if it fits it ships) and let you guys know
I'm pretty sure that a 67 w300 would have a 11" ten spline clutch,but with the larger (@ 1-3/8" ) dia input size.
- Roxyflash
- City: East Moline
- State: IL
The d500 also has the 1 3/8 10 spline input shaft.
