Adding power brakes 225 equipped..DONE!
- City: pittsfield
- State: MA
I'm almost afraid to start yet another Power Brake thread...please pardon me...
I've read a couple [3-4] power brake threads but none seem to address my need..
My 71 is a slant six, automatic. That said...I should have tons of room for a booster right? Keeping the 4 wheel drum, just want to ease pedal effort a bit.
Not being a mopar guy, can you suggest something that will interface with the firewall, and master cylinder. Or even a booster-m/c combo. I'm thinking maybe a early 70's Duster...Charger...Fury???
Thanks.
Thanks.
Re: adding power braks 225 equipped
I used an A Body Dart booster 30 years ago in my 66W100. Still in it. Had to custom fabricate the arm from the brake pedal to the booster adapter. Still working to this day.
71' s were available wth power brakes, I had my booster rebuilt by Prior reman in Texas. They had some boosters in stock then that was 3 years ago.
Prior to rebuilding I searched for a new one and had a hard time locating anything that just wasn't real generic.
Try doing a forum search for posts from Russ Ashley. He added a power brakegearjammer wrote:I'm almost afraid to start yet another Power Brake thread...please pardon me...
Thanks.
booster to a '69 W100.
- MrMopar
- City: Lompoc
This question answers itself, the 71 was available with power brakes.
Track down the parts that are different, linkage etc and buy a rebuilt booster/master (for a 71 Dodge Truck) from your local parts store.
As soon as you start trying to do something custom you are opening doors for problems.
Alan
Alan
- City: pittsfield
- State: MA
I'm a thinking...no local parts store is going to have availability on that part...
Think a 70 camper special booster is going to be close?
- City: Glendale,
- State: AZ
A 70 Camper Special should work, my only concern would be the push rod that goes from the brake pedal to master cylinder. Jim
- City: Brooklyn
- State: NY
Make sure you get the standoffs/brackets and pushrod with the booster and it should be a bolt-in deal. I know from looking at the junkyard that the 1969 up booster is different (bracket/linkage) is different than 1968 down. For mine I just found a '68 booster on ebay and had it rebuilt for my '68.
- City: pittsfield
- State: MA
I just picked up a booster off a 70 Camper Special. Coming in the mail so I don't really know what I've got yet....
LC from PA I have a 1971 D-100 Slant 6 factory power brakes if you need any info PM and I will check my truck to see how things are hooked up IT Brakes Alot better than manual LC
- City: pittsfield
- State: MA
Re: Adding power brakes 225 equipped..DONE!
I purchased a Booster off ebay. Seller said it was off a 70 Camper special...all I had to go on. Got it today and it couldn't have been any easier to install. Had to drill 4 holes in the firewall that matched the bolt pattern of the booster. Very easy as there are four factory indentation in the firewall from the factory already there.
The master cylinder was a direct bolt on. [four bolt pattern on mine, I guess some have a two bolt pattern.]
The rod to the pedal is already on the booster and was perfect fit. Original MC had studs where it was mounted to the firewall...Popped those out and the studs on the booster were a perfect match. Found a vacuum port and everything was golden. Just a very short test drive around the yard and so far so good.
the number 18268 is stamped on the front side of the booster under the M/C. I googled that number and it seems like it's similar to a 1970 Challenger. So I guess if you have a 1971 as I do, with a 4 bolt flange on the M/C, a 70 Challenger Booster may be a good place to start.
- Roxyflash
- City: East Moline
- State: IL
Great deal i too need to get some power brakes on my 66 d200 first thing is the powersteering its a must have my legs are stronger then my arms LOL
